I have a carrier desert master Model No.38HKC24US70-01 the problem is after switch on the unit...it will work at least 5 minutes and will be in a stand by (the green light in the inner unit is blinking)for another 5 minutes and the same continues for at least half an hour.After this the unit in stand by mode rest of the full time. It was't working in the rest 23.5 hrs.Is there any serious problem for the unit or can i manager it myself
Split unit all are in timer mode we need to cancell timer mode and menual on off mode
Posted on May 24, 2011
Desert master carrier ac compressor is leaking and due to leakage it is taking too much ampere due to it trips the breaker. what i have to do change only the compressor or the whole unit?
If only the compressor is faulty then you can repair it by just changing the compressor. This is a specialist job that requires specialist equipment and you wont be able to do it yourself unless you have this equipment. I suggest you contact a refrigeration repair service and get them to check it out.
May 25, 2016 | Carrier Heating & Cooling
We have the portable air condioner model LP1010snr and we have drained the tanks and still have the P2 warning. It will not start working. what can we do?
Turn the Master ON/Off Switch to OFF and unplug the unit for 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings.
Hope this helped you solve the problem.
Jul 09, 2011 | LG Heating & Cooling
Bulb blew in my dimplex michigan fire, model MCN20. I now can't get the bulbs to switch off with either the remote control or the on/off switch.
Stewart, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON and set the function controls manually (not with the remote) one at a time. If everything works as it should, the fire reset itself during the 12 - 15 minute timeout. If it didn't or that problem continues to reoccur, contact Dimplex North America, Technical Service at 888-346-7539.
Apr 27, 2011 | Heating & Cooling
Have Kenmore 85501 Air Cleaner. Unit will not restart after power failure. Send unit to Sears Service Center but they declined to fix unit. Tried to hold timer and function buttons for 5 seconds and...
Turn the Master ON/ OFF Switch to OFF and unplug the unit. Wait 12-15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set your controls. The 12-15 minute timeout should have allowed the unit to reset itself.
Apr 16, 2011 | Kenmore EnviroSense 85501 Air Purifier
Sir, needed for warehouse offshore hot climate
Does it have to be desert master?Every brand makes a 480V-4ton system.
Mar 20, 2010 | Heating & Cooling
Carrier Desert Master AC trips the fuse
1- check the fuse must support the current of the unit not less than (rla of the unit)
2- check freon pressure may below or toohigh causes compressor winding over heating
3- check fan motor winding
Sep 20, 2009 | Dometic Rooftop RV Air Conditioner
Unit Just working Half an hour
Without any tools it's hard for you to know what to do and without a manual you are better off having an exper to fix. here is cairrer web site where you can type in your zip code and buy the manual or get someone certified on carrier ac systems. carrier desert master Model No.38HKC24US70-01
Aug 25, 2009 | Heating & Cooling
My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Jun 17, 2009 | Carrier 36KCARMS Air Conditioner
Fabricate or not?
OK, can you provide a bit more info. What make and model is your HVAC...if you can give me the serial that would help too. What size tents are you using and what is the average ambient temp during the day?
Apr 14, 2009 | Heating & Cooling
Heating & Cooling Logo
492 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
