Question about Canon Cameras
I can't download my photos on my Canon A720. The computer doesn't detect my device and I have checked the USB port is fine. Is there something I should press on the camera to make it work? If not, have you any other suggestions?
  • 613 Answers
If you turned it on and nothing happens and there isn't a spot on the button for playback, you might need a registry cleaer such as ccleaner that is free from filehippo. You can also restart your pc.
Posted on Nov 05, 2010
Why does the usb connection not reconized?
Have you tried NOT connecting your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
As to why your USB connection isn't working, there are a lot of possibilities. You may not have the right driver. If you're going through a USB hub, you might try bypassing it and connecting directly. There could be something wrong with the cable. There could be something wrong with the computer's USB port. There could be something wrong with the camera's USB port.
The main reason camera manufacturers include a USB port on their cameras is not so you can use it to transfer photos. They put it there because other manufacturers put one on, and so the marketing department insists they do so as well.
May 09, 2012 | Canon PowerShot A720 IS Digital Camera
The camera doesn't download pics to the computer. It reads
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and isinexpensive. You can copy photos from other cameras and you can also downloadphotos off your memory card to someone else's computer without the need ofinstalling any programs.
May 05, 2012 | Canon PowerShot SD1200 IS / Digital IXUS...
My Canon printer PIXMA MP 800 cannot be3 installed with my windows xp. Help please
ARE YOU UNABLE TO INSTALL YOUR PRINTER AND OTHER DEVICE MOSTLY REASON ARE YOU HAVE NO SUITABLE DRIVER THE BEST STEP THE FIND DRIVER GO TO MY COMPUTER MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE OPEN http://devid.info SITE AND SEARCH YOUR DRIVER AFTER SEARCHING EXTRACT YOUR DRIVER ON ANY LOCATION GO TO DEVICE MANAGER, UPDATE DRIVER SELECT PATH OF DRIVER INSTALL DRIVER TO USE THIS STEPS
May 18, 2011 | Cannon Office Equipment & Supplies
Have a Canon A720 IS won't download.
Blame Microsoft updates. Try using a separate card reader instead of your camera.
Jan 04, 2010 | Cameras
I've downloaded the scanner software onto my computer, and I am able to make photo copies, but when I try to scan something the screen on the printer says "preparing," and nothing happens. Additionally,...
For that first go to device manager then uninstall all usb drivers.
Right click on my computer then click on property then hardware ->device manager.
Then you can see all driver list first uninstall all usb drivers 1 by 1.
Then also uninstall scannner driver from there.
Then again reinstall scanner driver.
then restart computer then check.
Make sure usb cable and usb ports works fine.Try usb cable in another ports.
If you havewn't driver disk you can download from below link.
click here
Select your operating system and download driver.
Let me know if you need more assistance.
Thanks.
Oct 18, 2009 | Canon Pixma MP480 All-In-One InkJet...
Cannot transfer pictures from CX7330 to computer. Worked fine about a month ago.
I have a Canon PowerShot A720 and have lost the disk to download drivers so I can get the photos off of my camera. Do you have any suggestions. I have tried to find them on the internet with no success. Help Please!!
Jun 10, 2009 | Canon PowerShot A720 IS Digital Camera
Canon powershot A720is continually powers my computer on and off
Don't thru the camera out the window as it is working on the other system.
I assume you are connecting the camera to the computer USB port; if yes, please check the USB drivers of the operating system on the computer. there might be a physical USB port issue, or USB driver issue or USB port over current issue.
Check all this things before connecting ur camera or check with any other USB device.
Regards,
k.vel
Mar 30, 2009 | Canon PowerShot A720 IS Digital Camera
Can't download to my pc from my canon powershot A720 IS
Have you installed your camera software?(driver) If you have try a different USB port.
Aug 15, 2008 | Canon PowerShot A70 Digital Camera
USB not decting plug n play devices
I would check the bios settings to make sure the motherboard settings relating to PnP are correct. Try playing around with those bios settings and see what works for you. Also try different usb ports, i have the same problems sometimes with certain ports on my desktop computer, try all of them at the front or the back of the computer. I would check the Compaq Presario website for drivers not AMD, installing new ones is a good idea just to make sure its not a driver issue.
Dec 21, 2007 | Computers & Internet
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
