Question about HP LaserJet 3600n Printer
COLD RESET HP 3600n - HP LaserJet 3600n Printer
    Novelist:
  • 170 Answers
Click Here for instructions on cold resetting a 3000, 3600 or an 3800 hp laserjet printer... Be sure to leave it marked as FixYa!! if this info helped...
Posted on Nov 07, 2010
Cold reset hp 3600n
To Perform a Cold Reset on HP Color LaserJet 3600n Printer
Step 1 - Turn the printer on.
Step 2 - Watch the control panel.
Step 3 - When the memory starts counting, press and hold the green (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
Step 4 - Release the (Select) button.
Step 5 - The control panel will display SELECT LANGUAGE.
Step 6 - Press (Down Arrow) button once. The control panel will display COLD RESET.
Step 7 - Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Jan 24, 2017 | HP Office Equipment & Supplies
How to cold reset
http://www.ehow.com/how_8337650_do-restart-color-laserjet-3600n.html
Instructions <:section>
    • 1 Turn the printericon1.png on and look for the control panel display to count the memory. When the memory count begins press and hold the green "select" button located on the front of the printer. When all three of the front control panels LED are lit release the "select" button.
    • 2 Press the "Down Arrow" once when you see the "Select Language" display. Press the "Select" button until your controlicon1.png displays "Cold Reset."
    • 3 Press the "Select" button and your printer will initialize a cold reset.
Jul 01, 2014 | HP LaserJet 3600n Printer
COLD RESET HP 3600n
Turn printer off. Turn it back on. When it starts to initialize press and hold "check mark" until all LEDs are lit.
Press "down arrow" until "COLD RESET" appears and then press "Check Mark".
Nov 24, 2011 | HP LaserJet 3600n Printer
Replace and reset fuser for hp 3600
I tried the reset fuser and your instructions do not work for the 3600n. reset supplies is under another category and new fuser kit is not an option?????
Nov 22, 2011 | HP LaserJet 3600n Printer
HP 3600n refilled and replaced micro chip but it's still only reads a 1/4 full. Are there any reset methods for this printer to over ride low toner messages?
You take your chances with refilled cartridges. The only way that I know to fix your problem is to use HP cartridges, new ones...not refilled.
Aug 26, 2011 | HP LaserJet 3600n Printer
Default password for HP Laserjet 3600n
by default an HP printer does not have an administrator password installed. if the printer asks for a password, this means that someone has installed it and only that person knows the password.
Sep 27, 2010 | HP LaserJet 3600n Printer
HP 3600n yellowish pages print out
Do replace the yellow cartridge first and see what happens.
Dec 30, 2009 | HP LaserJet 3600n Printer
Have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
May 26, 2009 | HP LaserJet 3600n Printer
HP 3600n Cartridge Memory Tag
Check the latch on the right side of the black cartridge. They have a problem with them breaking. There is a new style available.
Oct 18, 2008 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
1,371 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
