Question about Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop
Computer has frozen on windows logo
I downloaded an pando update and now my computer has frozen and I cant even run my product recovery disc
    Novelist:
  • 150 Answers
1) Which version of Windows ?
For the following discussion I am assuming it is 2000, XP
or higher. You may also want to print this, it's long.
2) Is this this the low resolution Windows logo on the black
screen?
3) Reboot the machine using the RESET switch and press F8
during the boot up:
After the post and memory test,
After the enumeration of the hard drives,
After the HD, I/O and interrupt vector information screen
(if it shows you any of these)
But before the Windows LOGO
(timing is critical so you have to experiment)
Also if you enter the BIOS, turn on all reporting screens,
memory tests ... etc for now.
4) If you hit the F8 Key at the correct time, Windows will
come back with a black and white prompt screen
asking you to chose:
a) reboot normally
b) reboot in safe mode
c) -//- with networking
d) -//- in console mode
e) reboot to last known good configuration
etc...
5) Chose the last known good configuration, this should restore
the system state back to the way it was before PANDO
update. If you get back into windows at this point, uninstall
the old pando and re-install it. Forget the upgrade.
6) If it still freezes, try to repeat the process, but this time
chose safe mode with networking.
7) If that fails choose safe mode (without networking)
this tell you if the network stack or drivers have been
corrupted, causing Windows to hang.
8) If you get in at this point, uninstall Pando ... etc.
9) If you still can't get in, try safe mode in console mode.
10) if you get in at this point, edit the boot.ini file to display
driver information during the boot process:
Assuming your boot is on drive C:, enter the following
commands at the command prompt:
C:\
cd \
attrib -R -S -H Boot.ini
Edit Boot.ini
This should open up the boot.ini file inside a primitive
DOS-like text editor, with a blue background.
Now look for a section called:
[operating systems]
multi(...)disk(..)rdisk(...)partition(...)\Windows="......"
Find the line that points to your windows installation.
The numbers in parenthesis represent the drive and
partition of the Windows installation using the universal
ARC format:
multi = disc controller, usually 0
disk = SCSI disk number, usually 0 for IDE's
rdisk = IDE disk identifier, usually 0 or 1
partition = partition number not including the EXTENDED
partition container.
These numbers, unlike numbers reported by windows tools
are zero based, so they can be inconsistent. The best advice
is to leave them alone, because you could totally lock your
self out of the system by setting them wrong.
Now...
At the end of the line describing the location of your windows,
after the last quotation mark, enter at least one space,
followed by the switch: /SOS
This switch causes windows drivers to be displayed
as they are loading.
Save the file, close the editor and reboot the machine in
normal mode.
Take note of the drivers as they are loading.
Don't worry about the ones that scroll of your screen,
it is the last one that loads, or the one after it that is
causing the problem.
Once you identify the bad driver, go back into the
safe-mode console, and disable the service using
the "sc" command. This gets a little more complicated,
but you can get help by typing "sc /?"
If you cannot get into safe mode in any mode,
The next step is to get into Windows using the RECOVERY
console from your windows installation installation disk.
1) Reboot the machine using the hardware reset switch.
2) Repeatedly press the BIOS access key during the memory
test (before and after if need be)
On most computers, this is the DEL key, but it could
also be F1, F2, F3, F10 etc., check your manual or
experiment until you get there.
3) Inside the BIOS settings, look for the STARTUP tab,
and find a setting for the device boot sequence.
4) Make sure that the CD (or DVD) drive is first in line,
(you should change it back when done)
This will make sure that the BIOS will not try to boot
the bad operating system first, and look to the CD
instead.
5) Insert the windows setup disk, and reboot the machine.
6) Let the setup do its thing, enumerate devices, accept the
license ****... etc, until you get a prompt asking you
to chose between REPAIRING or INSTALLING windows.
a) if you have a rescue disk, check Repair and follow
the instructions on the screen.
b) if you don't have a rescue disk the select INSTALL
(don't worry you will get one more chance to stop it)
Windows will do some more grunting, and growling,
then you will get another prompt asking you to chose
i) Install window
ii) Repair windows using the COMMAND CONSOLE.
chose the command console.
7) The setup program will now search your system
for Windows installations. Give it time, then
chose the correct drive/installation and login as
an administrator.
You may need the administrator's password if you had
previously created one. If you lost it, try booting it with
an older win 2000 disk, which ignores security.
8) If you got this far, Windows in now running in low level
console mode, from the installation CD.
You can edit the BOOT.INI file as I explained above to
display device drivers as they are loaded, so you can
identify the problem.
9) Once you ID the bad device driver, you can go back into
the Repair console to disable it.
At some point you have to decide on the path of least pain,
try to keep fixing Windows or re-install it, which depends on
the number of application you have to re-install also, and on the
overall complexity of you running environment.
Re-installing windows, drivers and apps takes about a day.
(although you can get it get is up and pretty in 30 minutes,
it doesn't really do anything useful until 24 hour later.)
Then there is the applications and personal setting which
can take much longer.
You can also spent several weeks trying to fix windows and fail,
depending on how bad it is.
I find that the best way to keep windows running is to partition
your hard drive:
1) Windows partition (running)
2) Swap file partition to reduce fragmentation
3) Application partition for programs
4) User Partition for your personal files
5) Spare windows installation for getting in to fix the other
windows (Don't you wish you had one now)
6) Windows and application drive backup parititions at
the end of the disk, which you keep hidden just in
case.
I know of 3 partitioning programs that allow you to manage,
adjust, copy, convert, merge and split partitions on the fly
without damaging the files they contain.
Partition Magic, originally by Power Quest, which was bought
out by Norton's/Symantech. This used to be a very good program
but Symantech has not updated it for larger hard drives and
offers abysmal support.
Acronis tools from Germany is now very good
Paragon also make a program I have not testes.
Hope this gets you started.
Martin
BTW please rate my articles, I need just over 1 percent to
get to "GURU" Thx.
Posted on Jun 14, 2008
    Novelist:
    Champion:
  • 210 Answers
Have you tried booting in safe mode first...!
Cheers
How can I restore my emachine el1200_06w without recovery discs
Boot in safe mode (Press F8 over and over while your computer is booting up). From there, go to your device manager and roll back the driver on this device.
Device Manager is in control panel, hardware and sound, then it's at the top under Devices and Printers.
Apr 08, 2013 | eMachines E Machines El 1200-06W Desktop...
My c160 webcam doesnt work says cant find driver for it what can i do
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality.
Feb 17, 2013 | Logitech Webcam C160 Web Camera 960-000668...
I downloaded files on my 8gb philips go gear SA52xx product connecting it to a pc and when i unplug the USB connection of my device after everything it has since then frozen and refusing to work even...
Hi leefordnarte,
You can find a lot of valuable resources on the Philips Support Site...I am not sure which specific model you have, but the Product Support Page for the SA5285/37 can be found here:
http://ow.ly/5XLe9
For the issue you described, I would attempt a Repair/Recovery - this process will restore your player to factory settings, as well as update the firmware in the process.
Try the Philips Device Manager software (found on the support site www.philips.com/support if you do not have your original software disc):
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Hope this helps - if so, let me know by rating this solution. If you have any additional questions or need assistance, you can reach Consumer Care at 1-888-744-5477.
Aug 08, 2011 | Philips Audio Players & Recorders
How do i reset my settings to factory settings if i cant get to my desktop but i cant do nothing because its on the windows xp??
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media.
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form. If your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Order form:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=Acer
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 10, 2011 | Acer Aspire One PC Notebook
Have contacted malwaredoctor virus. have run avast antivirus & malwarebytes scan & repair, they have isolated threats but the pc is erratic. system restore doesn't work.have tried the reload...
Okay, so it sounds as if you are basically willing to go back to a blank slate with just your operating system on board. Does system restore not allow a complete restore? Do you have a restore disc? Please tell me which Operating system you are using.
Please go to http://kaspersky.com and run an online virus check. Your Virus control program must not have been up to date and may still not be, so let's try another virus check here. If this check locates a problem, it will offer solutions as well. Follow them.
Have you tried any of the systems repair functions found at >start>all programs>maintenance or >accessories? I can't tell you exactly what until I know what sys you are using. I also need to know the make and model of your pc.
Please try cleaning up your computer too. under accessories you will find system tools. Do a disc cleanup and delte all the files it finds.
Also let me know what programs you have running in the background. The icons will be in the lower left taskbar. I can also help you find out ones that do not show there.
Please get back to me to see if we have had any success with the new virus check /cleanup or repair functions on your systemnand let me know what you Op sys is. Once I have that info, you may be able to use some online features to repair your system.
Dec 19, 2010 | Computers & Internet
I have a Sony VGC-RC310G desktop computer. Two nights ago, I was downloading updates for windows, from the Microsoft website. I turn it off when i went to bed, and restarted the following morning, only...
So, your description said that you turned off the computer during software update process, that sounds not good at all. Updates need to run to completion, or major failure happens.
You did not mention the version of Windows that you are using, so help is limited.
BE aware that a system restore means all data will be overwritten and lost. I suggest that you extract all data before you do anything. remove the hard drive and hook it up to a good computer, via USB and get all of your files and settings.
The machine probably has the restore files on the D:\drive.
Oct 22, 2010 | Sony VAIO® VGC-RC310G PC Desktop
The computer comes on but is frozen on Apple screen
I would try pressing f2 or f8 when first boots up, then change bios settings from first bootup device as cd rom drive, then hard disc as second drive, then place windows disc or recovery disc in pc, then reboot. and reinstall your software.
Oct 01, 2009 | Apple iMac G5 Desktop
RECOVERY DISCS FOR BALANCE CN6555 PC NOTEBOOK
Hi when you say you cant boot up, do you have any power going to the notebook, i.e. lights, drive firing up etc.,
If you have power and the Windows product key you can use an Windows installation disk to get you up and running. The disk itself doesn't have to be your own as long as the version you use is the same as the product key you own, usually found on the bottom of the unit.
For example MS Windows XP Home
I hope this information helps, if not please let me know
Apr 07, 2009 | Balance CN6555 Notebook
I m looking for recovery cd of my notebook TX 1301.
HP TX1301 - you should have got one with your computer or at least a utility on your computer which creates recovery discs using your own blank discs.
See this for Windows XP http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph08097
Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=&product=81351&docname=c00810334
If you are running Vista and you cant boot your computer , insert the vista installation disc into the drive , start the computer off the install disc , click repair my computer when you get the "Install Now" option to access vistas recovery tools from the disc
Jan 07, 2009 | Computers & Internet
Iphone
Try restarting software upgrade. Often this solve the problem.
Also press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Check also the following links:
iPhone: Basic troubleshooting
How to Reset a Frozen iPhone
How to Reset a Frozen iPhone or iPod
http://www.youtube.com/watch?v=Jzyy4puapig
Aug 11, 2008 | Apple iPhone Smartphone
Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Logo
311 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
