Question about Sony BDP-S350 Blu-Ray Player
My Sony 1080p HDMI LCD TV now says "NO SIGNAL" on the blue screen when I have my Sony Blu Ray playing. No changes have been made, it just all of a sudden quit receiving the signal either due to the TV or the Blu Ray player. I have checked the cable and connections and all are intact. My Cable TV works fine on the TV input. Is it my TV or my Blu Ray player?
I have the sane problem! Help me!
Posted on Apr 21, 2011
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
Jul 08, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
I cannot get a video signal from my sony blue ray--the tv acknowledges the HDMI hookup to the tv but no signal is going thru
first run a yellow cable to tv (AV) if does work it maybe a setting in blu-ray or TV look for any settings in the TV and blu-ray menu that says HDMI communications or something like that and turn it off. try to connect HDMI cable again.
Jan 12, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
When trying to connect my 4695D to a new Sony Blu Ray player BD 560 using HDMI with the output set on the Blu Ray to 1080P I cannot get a signal to appear on the TV. If I change the output to 720P I am...
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
Dec 28, 2009 | Samsung LN-S4695D 46 in. LCD HDTV
I need to unlock blue-ray sony bdp-s360
tv repeating hdmi signal out of range did a bad choice 1080p instead of 1080i how fix the problem? thank you
Nov 20, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
May 14, 2008 | Sony Playstation 3 (PS3) Console
Vsx-94txh
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
Dec 22, 2007 | Pioneer VSX-94TXH
Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Aug 08, 2007 | Sony Playstation 3 (PS3) Console
Sony BDP-S350 Blu-Ray Player Logo
373 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
