Question about Samsung Audio Players & Recorders
I have been playing my Whafferdale TV with DSTV, now i bought HT C655W Hometherater. I conneceted the HT to the TV but still the TV sound does not come out through surrounding speakers
Doodad
  • 64 Answers
SOURCE: How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Posted on Jan 06, 2008
SOURCE: Problem w/ surround sound for Onkyo HT-R430
You might have blow the fuse for those channels.
Posted on May 05, 2008
SOURCE: the surround sound only plays on dvd not tv
most tv shows will only be broadcast in 2.0 not 5.1 or higher. if you have a converter box, that may also be the problem.
Posted on Apr 14, 2009
SOURCE: samsung LED UE46B7020 tv wont play sound through my HT-C5500
i know this is going to sound stupid but i couldn't get mine to work either after following every instruction to the T. I then rechecked my optical digital connections again and found that I neglected to remove one on the rubber protective endings. I took it off and plugged the end back into my TV and BINGO! THEATER SOUND from my tv!
The Ticket
Posted on Jun 12, 2010
press the top right hand button on the remote for the ht-c5500 untill its display reads "D.IN" (Digital Input)
Posted on Jun 30, 2010
How do i get a Regents HT-391 surround sound system to play sound from my Logitech Revue with Google TV?
More than likely the regent system is needing and alternate audio source, via- analog, digital coax, optical ect... HAs it always been this way, or use to work?
May 22, 2014 | Logitech Revue with Google TV Refurbished
I am unable to play DVD from different region on my Samsung ht-c655w??
Hi!
Follow this:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER (middle button of the arrow keys) on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote.
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Player will turn itself off, otherwise turn off player with remote.
11. Turn power back on with remote.
Player is now Region Free.
Regards,
Pelu.
Mar 21, 2011 | Samsung Black DVD Player DVDC350
I have just bought the samsung ht c555 home cinema kit connected it to the the tv all is working well when playing a5.1 dvd but ihave no sound out of the system when on ordinary tv how do you get all 5...
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
Dec 24, 2010 | Samsung Audio Players & Recorders
Can not get my Samsung TV to recognize the ht system. I am able to get the sound out of the ht system and the video on the tv when i play dvds but the sound will not transfer from the tv to the ht system...
The way mine is hooked up is like this: Ps3, DirecTV box all plugged to my samsung TV and then only thing I have plugged into the Ht box is the hdmi out to TV and an Optical Cable from Tv to HT box. All audio is going to Tv then to HT box and plays all through hometheater box when it is on. Try the optical cable
Sep 22, 2010 | Samsung HTC650 Theater System
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
Sep 03, 2010 | Televison & Video
The tv was re conneceted after 2 wks. It played
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 18, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Connected my telefunken surround sound through my DSTV decoder, but it only plays the sound from 1 channel. How do I get the sound to match the channel I am watching?
telefunkin surround home theate system ? how do i connect my TV to my home theate? i dont see any sound outputs on the TV
Jul 14, 2009 | Audio Players & Recorders
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
Jun 14, 2009 | Samsung HT-P38 System
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
19 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
