Question about Sony Televison & Video
Hi,i just change the flyback of my sony KV-21JSR1 ,but still it's not working,it has sound(audio volume is working)but no raster,the flyback that i bought is only generic,because originals are not available,could it be the reason why its not working?
  • EDDIE Sep 29, 2013
    HI. I JUST I THE FLY BACK NO. OF KV-21JSR1
    fbt is working because its has sound incase of no raster video trouble. thats why no screen. can i ask for the no. of the fbt you got?
    Top Expert:
  • Sony Master
  • 75,599 Answers
Hello
Have you a digital multimter that can count frequency. if so the testing will be easier to you. Just count the requency at the collector point of horizontal driver transistor, or at the base of horizontal output transistor. it should come around 15.625KHz [15625Hz]. When the tv wors with no signal this frequency may differ, but come very near to it. When it synchronises with a picture, it won't vary and will remain constant.
If you have no frequency counter, just measure the voltage at the collector of horizontal driver transistor. It will be normally connected to the primary winding of the line drive transformer, which is very small transformer on the PCB. Then check the voltage at the other end of that trnsformer, where supply to the collector of the above said trasistor is given. The voltage at the collector side of the winding and at the other side of the winding must have some difference, if the frequency said above is present, and drive transistor is working.
If there is no voltage, check the resistor connected to that winding to main power supply for open, or the capacitor fitted to that point to negative for short,,, or check the continuity of the driver trasformer primary winding itself, or a short between its primary and secondary windings.
If all of there are ok, and still LOT doesn't works, check the supply voltage to lot. Being a 21" TV, its LOT supply voltage comes upto 125VDC or so. If it is also there, try replacing the horizontal output transistor. It also doesn't help, the Line Output Transformer you have replaced is not the exact match. Sony EHT transformers are critical in construction and in winding. Keep it in mind, and buy an another. If you need any assistance freom me, don't hesitate, ask me through Fixya. OK.
Posted on Nov 05, 2010
I have a Sony model KV-32S26 that will not turn on, been sitting for about 2 years. Had a tv repair guy tell me it was the flyback transformer. If that's the case, can I replace it myself? Thanks
1) You must test the a) fuse b) c.breaker inside c) diode, d) rectifier e) transformer f) filter. g) IC. regulator voltage and test it. If the problem persist you must go to the horizontal problem by lack of RASTER, now you test the transistor horizontal power, flyback. If you have some experience with the electronic you can try. If do not, better go to the repair shop Tv. Since you can have a electric shock by H.Voltage discharge.
God bless you
Oct 11, 2012 | Sony KV-32S26 32" TV
My tv shows black screen but has sound
1) the main problem is lack of Raster
2) see the block diagram, test Video Detector, the transformer or flyback, horizontal output transistor, rectifier HV,,
God blesss hyou
Sep 17, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony KV-27HFR TV, no picture no sound; but got HV
The high voltage transformer may be the problem, because it feeds back secondary voltages to different parts of the set, for example is the vertical deflection voltage present at the ic, if memory serves me there should be around 26volts, if it's missing it means the fuse is open or the flyback pin is not generating the voltage.
Mar 07, 2012 | Sony Televison & Video
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Sony KV-27S42 no sound and audio blinks four times
+13 & -13 requires for Vertical Deflection IC and produced by Flyback Transformer, these volts will be produced IF Horizontal deflection circuit works properly. so try to check H-Out Transistor and its necessary volts / signal. Pls also mention correct Model Number to provide you more help.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Jun 08, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
No picture but sound ok
HI,YOUR PROBLEM IS ON THE FLYBACK TRANSFORMER OF YOUR TV. YOU MUST REPLACE THIS BUT BE VERY CAREFUL REMOVING THE FLYBACK.
Nov 22, 2007 | Sony KV-32V40 32" TV
Sony trinitron 32 in. pip no video, (raster, with audio)
What you have described there is a classic example of the jungle IC failure. Ic301 Sony p/n 8-752-101-04. A pic with no color, and lines or grainy texture in the picture. Not a project you want to tackle if you don't have the proper soldering equipment or skills. And not a costly one at a good repair shop.. Only real hurdle is getting that heavy monster into the shop. To answer your question, yes what you described there is raster. Even the salt & pepper looking screen with no real decernable image is described as raster. In fact any image generated on the CRT is raster. And yes, these sets are prone to solder joint problems, usually ring cracking in circuits that generate the most heat.
May 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
223 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
