Question about RCA HD52W59 HDTV Projection Television
We have RCA Model HD52W59 and the input cable end broke; is that replaceable?
  • RCA Master
  • 8,617 Answers
Its possible to resolder the Connector but its a vert precise soldering. Its often easieast to replace the small signal board . You can get small signal boards from www.tvrepairworld.com
Posted on Nov 05, 2010
Cable connector broke off
You should be able to get a replacement Small signal board from www.tvrepairworld.com
Nov 15, 2011 | RCA HD52W59 HDTV Projection Television
I have a RCA Hd52w59 television that has a blurry red green blue colors on screen and the pics looked like they are caved in .any help ?
RED BLUE and Green are the component colors. If you are using component cables, which most likely you are, check to see if the Green has come unplugged. Try switching the cabls to a different input. Actually, if you get the same problem on another input that say....your DVD player is hooked to, you have a bad tv. If not, try to isolate it to the simplest thing first e.g. cables, input source, etc. Please don't forget to rate this solution for me.
Jan 21, 2011 | RCA HD52W59 HDTV Projection Television
No audio or sound
I'll assume you mean you want audio from the TV to enter the unnamed 'rca dvd and souround system ' as that is where audio should all converge.
For this purpose you should have an RCA audio cable pair running from the FIXED AUDIO L and R outputs to any available input on the unnamed audio electronics. If you use(d) the VARIABLE AUDIO outputs the TV's volume control would affect the sound at the electronics end.
Apr 05, 2010 | RCA RT2620 System
The antenna inputon back of television broke off,
It is possible to fix it by de-soldering RF Tuner Block from signal board of your TV and installing new one. This repair need soldering skills.
Mar 10, 2010 | RCA HD52W59 HDTV Projection Television
I have an rca model hd52w59 tv the problem is that it will come on and do fine then go to a blue screen after a few minutes it will come back on then keep recriprocating. Any suggestions?
Once it goes to a Blue Screen, check to see if you can get the On-Screen menu to come up. If so, you are losing sync from your source input and should check the cabling or another input to the TV.
Good luck
Jan 04, 2010 | RCA HD52W59 HDTV Projection Television
Why can i not get digital channels with cable i have a rca 52" model # hd52w59
YOU CAN ONLY GET DIGITAL ON THE CHANNELS THAT ARE BROADCASTING IN DIGITAL, AND SOME OF THEM ONLY BROADCAST DIGITAL IN PRIME TIME SHOWS. CHECK SETTINGS MUST BE ON 720 OR 1080... CHECK SETTINGS AND INPUT
Oct 10, 2009 | RCA HD52W59 HDTV Projection Television
TV RCA HD52W59 NO VIDEO
Sound like convergence supply problem (small fuse near flyback will be open.
Sep 17, 2009 | RCA HD52W59 HDTV Projection Television
Broke one end of the cable that connects my 2 behringer ms20 speakers.Which replacement part do i need?
What input were you plugged into? If you are talking about the cable that connects the two cabinets from right speaker to left speaker, it looks like a standard RCA cable to me. It basically connects the signal content from the right cabinet to the left cabinet. It should be a shielded unbalanced RCA to RCA cable.
May 13, 2009 | Behringer MS20 Digital Monitor Stereo...
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
Lcd tv
Is the correct model number HD52W59? Let me know as if the model number is a different one I may be able to help. As the 52W59 wont be available except maybe through RCA
May 03, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
