Question about Dell 5310n Laser Printer
Bourrage papier sur imprimante dell 5310n code erreur 241.10
  • 1056 Answers
SOURCE: Dell 5310n Manual
Right at the Dell site.
Here you go
http://support.dell.com/support/edocs/systems/prn5210/
Posted on Aug 26, 2008
SOURCE: Mon imprimante CANON PIXMA MP160 n'accepte plus le
error 32
Posted on Feb 27, 2010
mariolands
  • 2296 Answers
SOURCE: MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 18, 2011
fanaudi
  • 1381 Answers
SOURCE: bonjour je viens d aquerir
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Posted on Mar 20, 2011
Joed911
  • 4338 Answers
SOURCE: j'ai 1 hp photosmart C6180
Le caoutchouc marche dans les usures de cylindres, les faisant en bas lisser, donc ils ne prendront pas le papier. Quelquefois, ils sont vieillis, qui aussi les donne une texture arrondie plus lisse, causant des embouteillages. La r?paration rapide est d'animer ce cylindre avec un m?lange d'alcool et de savon. Etouffer un chiffon avec la solution et essuyer les cylindres nettoie avec cela. Cela est la marque les plus flexible et les embouteillages en papier cesseront. Si vous avez l'intention de garder votre imprimante
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 21, 2011
Comment enlever l erreur sc194 bourrage papier porte de droite
faudrait bien regarder le sensor, il y a surement un bout de papier la
Oct 06, 2014 | Gestetner RT45 1500 Sheet LCT 411339
J'ai 1 hp photosmart C6180 qui affiche toujours bourrage papier
Jul 21, 2011 | HP Photosmart C6180 All-In-One InkJet...
Mon imprimante canon ip 6600D marque fout 6A00 foutcode
This is caused by paper jam, you have to check the printer for unnatural obstacles inside it. I will try sollution in french:
Ceci est caus? par bourrage papier, vous devez v?rifier obstacles artificiels ? l'int?rieur de l'imprimante.
I hope this will help.
Jun 04, 2011 | Canon Pixma iP6600D InkJet Photo Printer
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Les deux voyants papier et point d'exclamation clignotes sans repture. salutations
Yat-il un code d'erreur que vous avez trouv?? Le code d'erreur indique un probl?me sp?cifique de l'imprimante, s'il vous pla?t v?rifier et de nous le faire savoir, nous serons heureux de vous aider.
Pour toute assistance suppl?mentaire, s'il vous pla?t contactez le Support technique Lexmark
Jan 30, 2011 | Lexmark E232 Laser Printer
When i turn it on the power light flashes alternatly green then amber 11 times it then pauses on green for 1-2 seconds and then repeats
check your ink status maybe you need to replace you ink cartridges you may have run out of ink, you will encounter these when you need to replace your ink or theres a paper jam in you printer
Nov 20, 2009 | Canon i9100 InkJet Photo Printer
On me propose d acheter d occasion une imprimante lexmark x 11500 au prix de 50euro. pouvez vous me dire en fran?ais si c est bien et se ce mod?le va s adapter a mon ordinateur qui est tout simple, de...
D'occasion a mon avis ( j'en ai un ) c'est cher ! mieux vaut en acheter un neuf pour quelques euros de plus - au moins il y a une garantie -
Je vous avertis a l' avance que l'encre est SUPER chere ! mais tout depend de vos besoins - le mien marche bien, pratique, mais finalement pour une copie par exemple, a mon avis, mieux vaut aller a la boutique du coin ! (parce que l' encre est si chere !) - mais ca depanne quand on est presse -
Le scanner marche bien - par contre je ne sais toujours pas comment imprimer les photos sur papier photos... Lexmark ne semble pas avoir d'encre speciale photo - je n'ai pas essaye l'encre normale sur papier photo avec cette imprimante, parce que mes essais avec une autre n'ont pas marche ....
J'espere que ca vus donne une idee ....
Mar 07, 2009 | Lexmark X1150 All-In-One InkJet Printer
Dell 5310n Laser Printer Logo
154 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
