Question about Sony BDP-S350 Blu-Ray Player
Hi There, I am getting the message cannot playback this disc (unknown format) when I insert any Blue ray disc, even discs that were working previously. I have just completed the firmware update but still no joy. Any ideas?
  • 45 Answers
SOURCE: firmware update
Here's the link to the newest firmware.
http://tinyurl.com/54a9wo
Posted on Jun 15, 2008
  • 3 Answers
SOURCE: how do I update the firmware on the blu-ray player
See the following URL and follow the instructions to the letter:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=BDPS301&upd_id=3977&os_id=7
Posted on Nov 30, 2008
SOURCE: firmware update for Element Blu-ray player
I had the same problem. You HAVE TO WAIT 5 minutes after you insert the firmware update disc and BEFORE you press enter on the YES or NO option for updating the firmware.
Posted on Apr 29, 2009
micromatikal
  • 2777 Answers
SOURCE: My BD HP-22 blu-ray player
This indicates the laser has actually failed on the blu ray side of things. The lasers are very delicate and almost always go bad before the dvd laser. If the unit is no longer under warranty you are going to want to either sell it for parts or juts keep it for a dvd player. I am so sorry about that but it's defniitely not a firmware issue or software setting, it is definitely the actual physical laser that has failed.
Thanks
Tim
Posted on Oct 10, 2010
  • 6771 Answers
SOURCE: my Sony Blue Ray has
If you can play standard dvd movies without a problem, then you are looking at a laser pickup assembly issue. The blue ray disc require more precision to provide the higher resolution when it is demanded, this is an early indicator of impending failure in the assembly. However there is a small chance that cleaning the laser pickup lens may solve the problem but unlikely.
Posted on Dec 29, 2010
Testimonial: "Thanks for the quick response, I will see if cleaning helps first. Greg,Texas"
PROSCAN TV DVD COMBO WON'T PLAY BURNED DISC STATES "UNKNOWN DISC"
Yes, review the manual and find out what formats the unit will read. you then tailor your cd/dvd burning sw to that format. Also make sure the unit can understand and playback mpeg files.
Oct 26, 2015 | Proscan Televison & Video
Unable to get any dvd to play.
It should also play---most likely a dirty or bad Optical Pickup in the unit---try to record a disc and play back on another unit?
Nov 02, 2012 | Televison & Video
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
We have just puchased a PD9000 potable DVD player. Will it play a Blue ray disc?
Unfortunately, this model does not support Blu-Ray discs. It supports DVD and CD playback only.
It does support DVD, DVD+/-R, DVD+/-RW, (S)VCD, CD formats, MP3-CD, CD and CD-RW playback. It will also allow you to view jpeg picture discs as well.
Feb 28, 2011 | Philips Car Audio & Video
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
"no disc" message when disc is inserted
Id the disc clean of debris dust and scratches? Cleaned the unit aswell with a blue ray cleaning kit? Please do these things, if you find this helpful please use Fixya when rating Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 26, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Disc error "playback feature may not be available on this disc"
the message you are getting is the machines waay of telling you that it can not read that disc. which means you will have to burn your discs in a different format. or your are using a type of disc it does not recognize.
tom
Dec 26, 2008 | Televison & Video
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
Sony BDP-S350 Blu-Ray Player Logo
334 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
