Question about Panasonic Panafax UF-790 Plain Paper Laser Fax
Panafax uf-790 - info code = 011
My error message says check cassette, info code = 011. I changed the toner cartridge but that doesn't seem to be what is wrong. Can you assist?
Dianne
  • 134 Answers
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Posted on Jun 14, 2008
I had the same problem. Solution? I realized I did not push the cassette with paper hard enough so the fax could not load the paper. Try that!
Posted on Feb 20, 2009
    Sergeant:
  • 284 Answers
Code=011 means that the machine cant see the cassette . there is a way to trick the machine seeing the cassette. leave a email address and i will tell you how to do it.
Posted on Sep 22, 2008
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Alarm - check cassette info code 011 - what is
The tab on the base of the paper cassette is broken off.
How to cheat it:
Remove the paper cassette
remove the tray in the back
remove the toner cartridge
set the machine upright
Wad up a small piece of electrical tape and shove it into the small black u-shaped sensor on the left side bottom.
it should work OK after this.
Nov 20, 2009 | Panasonic Office Equipment & Supplies
We cannot recieve faxes check cassette error code 011
The small tip on the left side of the paper cassette is broken off.
wad up a small piece of electrical tape up and stick it into the black u-shaped sensor hole where the tip used to go in.
Jul 07, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Fax machine with error code. Panasonic UF-780. Error: "Check cassette info code = 011"
you broke the tab on the back of the paper cassette. if you look in where the cassette goes on the back left you will see a hole with a sensor that looks kinda like a upside down letter U . put paper inbetween the sensor and the machine should say out of paper and put the cassette back and you should be fine
Dec 29, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
I got Panafax UF-595 and this fax keeps saying "check cassette info code=011" and does nothing else. What am I supposed to do to make it work?
There is a small plastic tab broken off of the front of the paper cassette.
remove the rear brown tray
remove the toner
set the machine on it's back side
stick the tape in the black U-shaped photo sensor at the bottom left corner of the machine to cheat it.
Dec 10, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Error 011
Where is the broken left tab. Sometimes on that cassette the tab breaks that tells the unit that the paper cassette is installed. If this is the case then the tray has to be replaced.
Nov 06, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
How to fix this code????
there is a little tab on the cassette that is broken. leave me a way to email or talk to you and this could be resolved
Sep 24, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
2,062 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
