Samsung B3410 Cell Phone Logo
Posted on Nov 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the phone but will not accept USB. When you connect the USB it charges the battery.Can you help me somehow???
Anonymous
Level 2:
  • Expert 148 Answers
  • Posted on Nov 05, 2010
Anonymous
Expert
Level 2:
Answers
148
Questions
6
Helped
31399
Points
403
Please ensure that if you get a CD with phone manuel,Then install the software from the cd and reconnect with computer then you can connect computer,or you can change USB mode option from USB settings somethings like that in the menu.Thanks
Anonymous
Level 2:
Sniper:
  • Expert 79 Answers
Anonymous
Expert
Level 2:
Sniper:
Answers
79
Questions
0
Helped
18107
Points
303
Install proper suite in yiour pc for your phone to aceess internet in ur pc via phone
Lenova tab s8 wont charge help
Hi, it maybe possibly your battery to drained flattened to the point where it cannot accept a charge from the wall charger. the best thing to do is to try and trickle charge your tablet from a low voltage/amperage connection. Either a powered on PC USB port to the charging connector on your tablet, or from a low power phone charger (5v/500ma). It has been pretty well documented that lithium batteries do not like to be drained fully & it may be that the battery in your tablet has drained so low that it cannot accept a charge from the Lenovo a/c charger.
Try a trickle charge for 8-10 hours (or longer) on your tablet & see if that gets enough charge into your battery to enable it to recognise & accept a charge from the a/c charger.
Else it replacement of charger or some hardware failure in your tablet
My isb283 won't charge, help
Hi there
I can only think of 2 possibilities here:
Firstly a wire in the cable, or in the speaker box has come loose somehow so that there is no circuit created to charge the batteries, or
Secondly, the batteries have been charged and discharged so often that they will no longer accept a charge and need replacing.
Hope this is helpful, if so would you please register that with Fixya
Cheers
My samsung intercept will not charge do to "battery temperature" is there a way i could clean the battery or bypass this somehow?
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
3helpful
Phone will not charge
No reset button, it sounds like the internal handset charging circuit is blown.
I have a karbonnk415 which switches off itself frequently. please help me
Be sure it has a new battery, they only last 1-2 years, even if plugged in and fully charge if it doesn't have a good battery left then it will do this. Next see if you can connect to a PC somehow via USB etc, the flash with a new firmware. Most phones use SBF on a motorola, other company sites you can get the file and then reflash sometimes with more features
Jul 10, 2011 • Cell Phones
I have n97 but there is problem that when i connect the charger the led is on & battery bar showed no response nor charged with usb cable or usb charger .what should i do because in my city no one can...
It looks like the battery in the phone is not accepting the charge. This can be happening if the battery has gone bad. Please contact Nokia people for further assistance.
Please feel free to contact us for further information.
Jan 05, 2011 • Cell Phones
3helpful
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
1helpful
3answers
I left my power cord at work
A USB port supplies 5v at 1amp
If you only draw 500ma off there is a chance that the voltage will go up to 6v
Not a killer if it wants 5v but you will cook the phone if it only needs 3.7v
Some phones will only accept 3.7v (Some Nokia units)
Look at the phone battery and it will tell you what it needs
P1i display problem...
Solution Description:
  1. Back up your data using the Sony Ericsson PC suite, then perform Update Service as described below
  2. Log on to: http://www.sonyericsson.com/cws/support/softwaredownloads/p1i?cc=hk&lc=en
  3. Download and install Update Service on your computer to keep the software in your phone up-to-date and ensure optimum performance from your phone.
  4. When the download is complete, an Update Service shortcut will be created on your desktop.
  5. While still connected to the Internet, click the ‘Update Service’ shortcut icon on your desktop
  6. Sony Ericsson window will pop up and downloading will begin. Allow the downloading to run complete to 100%
  7. Another Sony Ericsson window showing different countries’ languages will pop up, select your preferred language.
  8. Sony Ericsson ‘Welcome to Update Service’ window will pop up, showing ‘Exit’ on the left-hand side and ‘Start’ on the right-hand side.
  9. Click the ‘Start’ icon and select ‘Agree’ on the ‘Term of Use’ page that pops up
  10. Select your phone type and click on ‘Continue’
  11. Highlight your specific phone type and select ‘Continue’
  12. Follow the instructions as shown below:
- Make sure your phone is fully charged
- Connect the USB cable to a USB port on your computer
- Turn off your phone
- Remove and reinsert the battery
- Press and hold the ‘C’ button down while plugging the USB cable to the computer
- Continue to hold the ‘C’ button down until the instruction number ‘7’ on the Update Service comes up (i.e. Instructing you to ‘Release the ‘C’ button)
  1. Allow the update to run to the end
  2. When the system informs you that the latest update has already been installed on your system, click on ‘Continue Anyway’
  3. Click ‘Yes’ to all subsequent questions
  4. Allow the update to fully run to the end
  5. When update is complete, disconnect the USB from the computer and phone
  6. Remove and reinsert the phone battery
  7. Power on your Sony Ericsson P1i phone
  8. Congratulation!!!
NB: since the phone is not powering on, you may not be able to know whether the battery is fully charged. Hence, you will need to use a Sony Ericsson Deskstand. Connect the Battery Charger to its slot on the Deskstand and the USB cable to its slot simultaneously. This enables the battery to charge while the update is also running.
2answers
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
