Question about Krups FBC212 1600 Watts Toaster Oven with Convection Cooking
Can you replace a broken heating element? - Krups FBC212 1600 Watts Toaster Oven with Convection Cooking
The heating element on my Hamilton Beach toaster oven 31134 has a hole in the covering and smells when I use it. Is that safe? Can I replace the heating element?
The element is failing and while it will probably not catch fire, it is better to be safe than sorry and just replace it. Does not look like a replacement element is offered. Sears has this toaster oven for $22.49 + $6.99 shipping.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
Dec 10, 2016 | Hamilton Beach Toaster Ovens
Parts heating element
I received a new euro-pro ritisserie convection oven for Christmas and I just love it, but, the heat bars stopped heating. I miss it so much and don,t know what to do to fix it. Barb Tyrley
Oct 11, 2013 | Euro-Pro TO161 Toaster Oven with...
The lower heating elements on my GRV660 do not heat up. Is this an easy repair or should I scrap it?
first you need to find out if its the elements or /broken wire feed /or cut out....Get a parts price 1st elements vary in cost average perhaps £30....plus labour, depending on age may not be worth it...cheers
Apr 21, 2011 | George Foreman GRV660 Toaster Oven with...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Krups FBC212 1600 Watts Toaster Oven with Convection Cooking Logo
61 people viewed this question
Top Krups Toaster Ovens Experts
Stan Ford
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
