Question about Sony PlayStation Portable (PSP) Console
The connection to the access point timed out - Sony PlayStation Portable (PSP) Console
    Sergeant:
  • 158 Answers
This is do to a weak signal to the WIFI.
Make sure there is nothing blocking your connection an try detecting a new connection,
Posted on Nov 05, 2010
Every time i get on the enternet with my y fiy it takes fore ever to connect what can i do ??
Hi
Generally speaking connection to a WiFi access point takes around 10-15 seconds depending upon the equipment concerned. Taking a long time to connect indicates a potentially weak signal at the equipment trying to connect. The general requirements for a good, and quick, connection are:
  1. Keep the equipment as close to the access point as possible
  2. Make sure that the line between the access point and the equipment is uncluttered, especially by anything metal which will block the signal.
  3. Make sure that the channel on the access point is different fro other access points nearby to ensure that interference from other access points does not happen.
Hope this helps
Cheers
Jan 31, 2015 | Video Game Consoles & Games
Have to reset wireless access point several times a day
Make sure it's not getting too hot. That is usually the problem.
Mar 21, 2014 | NetGear R6300 WiFi Router
I have an issue with Wireless Access Point D-Link DAP 1155 When i'm connected to the internet via WiFi by mobile device (different ones Galaxy Note 1, Galaxy Note 2, Galaxy ACE) when browsing internet is...
Do other wireless laptops connect to your wireless router, and give good speeds? Do you have many wireless networks, other than your own, that show up when you try to connect? It could be interference from other wireless networks in your vicinity.
Aug 21, 2013 | D-Link Computers & Internet
Unable to connect to the access point
Hi tissa,
I see you are unable to connect to your Access Point as noted on the question provided.
First console cannot connect to an Access point if it is Password protected.
You will need to disable the Password or Network Access key from your Router to be able to get your DSi to connect to your Access Point freely.
To get security with your Nintendo DSi connecting to your Access Point in your Router setting you can enable the MAC Address filtering and get your devices MAC addresses and have it registered or input in your Routers MAC Address Filtering to be able to get your DSi connected wireless and at the same time have your Laptops and other wireless devices connected.
for the MAC address you can call you Internet Service provider on the issue to give you detailed info on how to access you Router settings for the said connection.
I hope that this will help.
Thank you fo choosing Fixya,
mvincentc
Jul 15, 2011 | Nintendo DSi White Console
We have more than one computor in the house and we have reset arris box in order to connect........... in the process the computor that is connected will get booted off the internet...isnt it possible to...
All the computers in the house should connect to the netgear wireless.
The netgear should in turn connect to the arris modem.
And yes, all the computers should be able to access the internet at the same time when setup this way. You shouldn't have to reset the modem at all.
Jan 24, 2011 | NetGear (WG602MES) 802.11g/b Wireless...
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Sometimes i try to ping the wireless access point and i get the message 'Request time out',i receive this message even if im directly connected to the access point.what should i do
When you connect the computer directly to the access point, you might not be getting IP address on your computer.
You will need to assign a static IP address on your computer in the range of default IP address of the Access point.
Click Here for More info on access point
Oct 08, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Connection Problem
Is your access point connected to a router?
Aug 13, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
Select the access point that you want to use.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
Test the connection.
If you select [Test Connection], the system will connect to the selected access point.
14.
Confirm the connection test results.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
151 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
