Question about Dishwashers
My dish washer flooded and i have have two flashing lights on. slened the filters and took off water supply and re attached still no change.Book says it is on protection from flooding. how do i sort out the problem?
    President:
  • 1,140 Answers
Hi Tony,
I'm going to need some more information from you, so please post back with the following details:
1. Brand/Model of washer
2. You said it "flooded" - was water escaping from the machine? Where? From underneath or from the door area?
3. Is there still water in the bottom of the wash compartment now?
4. You said you cleaned the filters - were they blocked up?
Hope to hear back from you asap. Keep the water supply turned off for the moment.
Regards,
BElectric
Posted on Nov 05, 2010
  • DILLIGAF
    DILLIGAF Nov 05, 2010
    Also, is your machine fully integrated or freestanding? Can you pull it out from under the counter?
I Have gsd422ox6BB Dish washer that all it does is flash the reset light.
Flashing reset light could mean the flood switch is turned on. There could be water in the motor compartment of the dishwasher. To get this water out, you will need to take the dishwasher out from the kitchen bench and turn it side to side a few times so that water comes out on the floor. Make sure the power mains connection is taken out.
If this does not help then the flood switch itself might be faulty.
Check parts on this site.
http://www.appliancepartspros.com/body-parts-for-ge-gsd4220x72bb.html
Feb 16, 2014 | GE Dishwasher Power Board - WD21X771
How do you replace water intake hose on machine
under the kitchen sink there is a water valve that is attach to a hose that goes in behind the dish washer that feed the water to it,,,,the dish washer is attached to the counter by two screws in the front of it,,take them out and the you can slowly pull out the unit,,,to change out the water feeder hose,,but make sure you shut off the water going to the dish washer first
Feb 19, 2011 | Dishwashers
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dish washer will not start all i get is a red light saying check water
Are you sure the red light 'means' water? If so, check the small tap near the machine where the flexible hose is attached to the mains water supply. It may have been turned off or there may be a kink in the flexible hose.
Good luck.
Jul 20, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
Sep 19, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Wash leaves a white film over dishes and wash / dry lights flash
sounds like you may not be getting enough water.it will stop if water is in short supply.this may be if you are running washer at the same time.or running a bath.if hot water is in short supply,this maybe a hotwater heater problem.have you been running out of hot water when showering or bathing?
Aug 12, 2009 | Dishwashers
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
I have an f1 fault on the display of the dish drawer dd-603ss which i believe is the flood switch activation would you be able to help me reset it
Have you checked that there is no water remaining in the base of the dishwasher? There is probably a float attached to a microswitch in the base of the machine. A cup of water left in the base of the washer could be enough to trip the flood activation switch.
You could try tilting the dishwasher through 45 degrees to see if there is any water left inside the base.
Mar 28, 2008 | Ariston Technologies L63SNA Stainless...
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
