Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Compressor is extremely hot
The fan stop working, so I changed out the fan. The compressor is extremely hot to touch. Is that normal? I have been running a portable fan on the compressor to try to help cool it, because the fan itself is not cooling. The fridge temp. is holding at 41 degrees. The compressor is so hot it burned my water line, which is what caused the water to be on the floor when I dispensed water. Thanks
  • 1 more comment
  • stinkerbink Jun 20, 2008
    Replace the back panel and the temp is holding!!
  • Anonymous Mar 22, 2014
    The door panel is not working. What can be the problem
  • Anonymous Mar 30, 2014
    I have a Estate Mod:ts25cgxtd and will not cool. Clicking noise from the overload protection and the coolant fan is not running under by yet compressor. Compressor is hot. Please help. Thanks!
  • 828 Answers
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Posted on Jun 15, 2008
  • James Helmer
    James Helmer Jun 20, 2008
    Now come back and rate the answer we gave you. Its nice to be needed.
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
The center of the fridge where the doors seal is very hot. Took of back cover, coolant lines are extremly hot compressor making buzzing sound.
When you were at the back behind the compressor did ya notice that the fan thier by the compressor was running, what will make that center divider bar very hot (it's normal to be warm) is due to the fan by the compressor not running or the coil also near the compressor being clogged with dust. So check that fan and replace if not running and also be sure to clean that coil free of all the dust ( the coil should be cleaned every 6 months as normal maintiance)
GENE
Oct 04, 2011 | Whirlpool GD5SHAX Side by Side...
The gasket around my refrigerator is too hot to touch, what is wrong?
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
Jun 07, 2010 | Whirlpool Refrigerators
Cabinet flanges and mullion very hot to the touch and not cooling at all, model ed25qf
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I don't know the model number but our refrigerator is approximately 6 years old and is a side-by-side model. My problem is that the metal frame that separates the two compartments which touches the rubber...
Usually when the outside of the refrigerator is hot, there is some problem in the refrigerant cycle. I suspect that if you reach under the refrigerator and touch one of the coils, it will be very hot, too.
First, look at the coils and see if they are dirty. If so, clean them good. Second, the compressor should be running properly (I assume it will be.) Third, make sure the compressor fan is turning. If this fan doesn't operate properly, the heat in the compressor coil will not be removed and transferred to the room air. It certainly sounds like the heat is not being removed from the coil since it is so hot.
If the compressor fan is not turning, you will likely have to replace the fan motor.
Oct 19, 2009 | Refrigerators
Fridge sounds like it is running but it wont cool cleaned the dust out of the back and cleaned the filters
Make sure the compressor fan is running. It is probably underneath the unit close to the back.
Have you cleaned the coils? Do they feel extremely hot to the touch?
If the compressor fan stops running, the coils will be very hot because the heat the refrigerant contains is not being released into the air.
Oct 10, 2009 | Refrigerators
Hi, the fridge side of my lg is not cooling enough. The freezer is fine. The black compressor in the back is extremely hot to the touch. What can I do?
If the evaporator fan stops that is next to the compressor that will cause this. The compressor being so hot does indicate that the compressor is under a load and possibly the fan or the start relay is causing the compressor to cut itself off too many times. I believe you have a sneaky condenser fan stop during its job and causes the compressor to overheat.
Sep 19, 2009 | LG LSC26905TT Side by Side Refrigerator
Freezer not freezing, fan in rear bottom of unit not running, condenser extremely hot to touch. ge gdl20kcsabs
Hi, If the compressor is running but the fan is not, you will need to replace the fan motor. First make sure that there is nothing stopping the fan blade.
If you have a window or box fan, let it blow on the compressor to cool it down. This will help you get by until you can replace the condensor fan motor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Refrigerators
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Center divider of refrigerator is extremely hot to touch. Is this normal? I don't recall it being hot. The refrigerator is operating normally.
Turns out a circuit board had failed and the fan (back of frig) was not working. Because of this, coils were overheating which triggered the icemaker to stop functioning. Until the part was replaced, we put a portable fan in the back and within a day, things were cooling down and the icemaker was functioning again.
The part with installation was $200. Took less than a week for the part to arrive.
Jun 07, 2008 | Whirlpool Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
483 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
