Question about Dishwashers
Dishwasher conrol panel light comes on but it wont go into wash cycle
Dishwasher does not turn on. the electronic panel lights up for the normal wash function but it wont go on when I push wash. I checked continuity of the thermal fuse. What else can I do?
  • jad_rn Jun 15, 2008
    some lights work,some don't. Will not turn on for washing. Will turn on when the cancel/drain button is pushed. I disconnected power for over a minute and randomly pressed buttons hoping that the computer would readjust.This did not help or change what it was doing.
  • sajata2004 Sep 15, 2008
    panel light comes on even when the latch is not locked. Dishwasher willnot start
    Problem Solver:
  • 12 Answers
All dishwashers usually start by draining first, if your machine does not detect that your machine is empty it will not start to wash. There are a few resons why this can happen, could be the pressure switch is stuck. Some machines ie bosch have a float switch mounted in the base so if your machine has leaked underneath and lifted the switch it will just stay on drain.... would help to know the make and model number
Posted on Jun 15, 2008
Power is to the dishwasher put it wont turn on
hello first check yor breaker make sure not tripped.
next check for lights in your panel.
perform a normal wash if no luck
next perform a service diagnostics cycle.
note sercice diags. works on Maytag MDB7600 series.
press the following keys in less than 6 secs.
HeatedDry > Normal > HeatedDry > Normal
to advance machine cycles press Start/Resume key.
blessings,
e.
May 22, 2014 | Maytag Dishwasher
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Dishwasher won't start - lights for Normal Wash and Cancel are flashing
check the controls,make sure that they are not stuck.
Dec 31, 2011 | Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishlex dishwasher
Theres a problem with the water level sensor or the main electronic control PCB.
Apr 21, 2006 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwashers Logo
321 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
