Question about Harman Kardon SoundSticks II Computer Speakers
1. the volume is blocked on maximum, the loudest, the volume button doesn't work anymore 2. I would like to open the bubble, for one to clean the inside, but it seems inpossible, but I'm sure it must be possible for somebody, my product, soundsticks ll is no longer under guaranty, so I would like to see if I can do anything myself.
  • aksilvest Nov 08, 2010
    Yes, I left the speakers unplugged for a day and yes they seem to be working fine. There are objects that I would like to remove from the interieur for aesthetic reasons but I guess it is just not reasonable to pry open the thing.
    Thank you, Amelia Enlow-Silvestre
    President:
  • 2,777 Answers
I doubt it is anything just stuck in the device, it is an electrical issue of the volume knob not sensing the turning up / down of the volume. Have you tried simply unplugging the device for at least 5 minutes to allow it all to reset and power to drain from the capacitors? This will usually fix a problem like yours.
Please give it a try and let me know, just reply to my answer here and I will be right back with you and we can keep going with it.
Thanks,
Tim
Posted on Nov 05, 2010
I cannot remember my unlock pattern on my samsung GT-s5360
if you did not remember your unlock pattern ,you cannot open your phone anymore so you need to reset your phone like this...
1. Power off phone
2. Press and hold Home Button ( middle ) + Volume Up + power on button
3. Wait for 5 second until Android System Recovery menu appear
4. There are 4 options
reboot system now
apply update from sdcar
wipe data/factory reset
wipe cache partition
5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
6. After the process done, phone will reboot.
Sep 28, 2012 | Samsung Galaxy S GTI9000 Smartphone
Can't find how to adjust message tone volume
Message tone and volume works together,so if you have your ring tone volume at the loudest level, the alert tone for messages will be at the loudest as well. If you want to adjust the volume follow these steps:
go to settings --> personal --> profiles --> choose any profile that you want to be activated on your phone --> options --> personalized --> ringing volume --> choose from volume 1 to 5 as the loudest --> press ok then click back once --> options --> activate
From there you are good to go.
Thanks for choosing www.fixya.com
Dec 09, 2011 | Nokia E63 Cell Phone
My Dell Latitude E5500 speaker is too low, how to increase volume?
If you have volume control in the system tray (bottom right corner), double-click it. In Windows XP you will see all the sound controls. Increase all to the maximum level (except microphone).
Use the buttons close to the screen to increase the volume.
There is a volume control in the player you are using. Increase it to the maximum.
If it doesn't help, please let us know.
Sep 10, 2011 | Dell Latitude E5500 Laptop
My son's Leapster Explorer suddenly has no sound. If you hit the increase sound button, nothing happens. If you hit the decrease button you see the volume bar on the bottom of the page. Do you know...
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
Jun 14, 2011 | LeapFrog Leapster Explorer Learning Game...
The volume button doesn't work on our leapster explorer. It shows that the volume is at the lowest point, but it will not increase so we can hear it. We tried replacing the batteries and that didn't...
Mar 17, 2011 | LeapFrog Leapster Explorer Learning...
My Nokia 5230's volume suddenly went very low. Either I've made a call or receive a call, the volume when answering the phone is very low. I've increased the handset volume to maximum but it's still low....
Please see if there is dirt clogging on the earpiece that would have reduced the volume from the speaker. If so use a pin and soft cotton to clean or you must open the cover and use a brush and air jet.
Secondly the possible weakness of the speaker/earpiece or the weakness of the low power output amplifier is another possibility.
Feb 18, 2011 | Nokia 5230 Cell Phone
Why does my harmon/kardon speakers not playing louder ?
Perhaps, that is the loudest your speaker can make sound. Please check the volume of the speaker if it has been set to maximum.
Also, double click the speaker icon beside your computer's clock (system time) and try to see if the Master Volume is set to Maximum.
Dec 20, 2009 | Harman Kardon SoundSticks II Computer...
Remote, menu button, volume up buttons dont work anymore
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Nov 17, 2008 | RCA F32650 32" TV
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Harman Kardon SoundSticks II Computer Speakers Logo
788 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
