Question about Toshiba Portege R100 Notebook
Can not change Bios Boot Device
Toshiba Portege R100,
I can not boot from USB Device and can not change bios boot priority
bios boot priority is invisible
it like this HDD-Floppy-USB CDRom-
now it can boot only from HDD and F12 option also not work
Please solv this problem
thanks
  • 1 more comment
  • Anonymous Jun 17, 2008
    I am do not connect with USB HUB
  • blood knight Dec 04, 2008
    cannot change boot devise of dell latitude CPt in fact cannot change any settings please advise and give a solution
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is your USB device you want to boot from connected to a USB hub?
Remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Posted on Jun 18, 2008
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Remove bios pass word
You can type in the same in google search and you will be provided with detailed step-by step approach. This will help u for sure.
Thank you....!!!!!!!!
Feb 08, 2008 | Toshiba Portege R100 Notebook
Usb boot drive using bios
You may need to enable USB boot function in the BIOS or change the boot order. In some cases the USB boot function has to be forced from boot priority in the BIOS.
Or goto the boot menu when you first turn the PC on there should be an option to use USB Boot assuming the option is enabled in the BIOS already.
Nov 22, 2013 | Toshiba Satellite C655-S5125
I have a old Toshiba Portege 7100that i am trying to boot from a usb hardrive. When i start the computer up it says starting.Then 2 seconds later it says insert system drive and press any button to boot....
this model is too old to boot from a usb version1
maybe you can flash the bios to upgrade usb1 to usb version 2
or, load the ubuntu linux operating system using a CD
Sep 30, 2013 | Toshiba Portege 7100 Notebook
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
How do i get my toshiba portege m 100 to boot from cd
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps good luck
Sep 13, 2010 | Toshiba Portege M100 Notebook
Toshiba portege r100
With the notebook off plug the USB drive into a port, hold down "F12" when powering up and choose your Boot-device (USB).
If there is no option to boot from the USB (Removable Device) then chances are you are going to need a BIOS update which you can download from the Toshiba support website.
Regards.
Jan 14, 2010 | Toshiba Portege R100 Notebook
How to booting cd for my drive
turn on then immediately start pressing the left or right arrow. Highling the cd drive (or usb if you are using an external cd drive) then press enter.
Sep 30, 2009 | Toshiba Portege M200 Notebook
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
Jan 25, 2009 | Toshiba Portege R100 Tablet PC
Laptop will not go in BIOS or boot up
We use these and several times I have had to pull the battery, disconnect the power cord and hold the power button for 30 seconds (count slow). After that, it boots fine.
Nov 10, 2008 | Toshiba Portege R100 Tablet PC
Toshiba Portege R100 Notebook Logo
592 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
