Question about Hotpoint 24 in. HDA3740G Stainless Steel Built-in Dishwasher
HOTPOINT LFT114 DISHWASHER, FAULT ON/OFF LIGHT FLASHES +THE 50C ECO LIGHT FLASHES & NO HEAT. IS IT JUST THE ELERMENT . mANY THANKS FOR YOUR TIME.
SOURCE: hotpoint fdw60 eco error code
I would like to thank Philhusbands for his advice on flashing eco light. After being told by hotpoint i would need an engineer plus call out fee. i decided to take a quick look on internet & to my surprise found this artical. So after reading it i did as advised & tipped my dishwasher to one side low & behold water came gushing out. After several minutes of mopping tried selecting programme again & it's working !!Yippee so than you who ever you are.
Posted on Nov 08, 2008
SOURCE: hotpoint dishwasher dwf50
i had the same problem and like an idiot paid for hotpoint to come out and all the guy done was tip the dishwasher backwards to empty the water(which he didn't clean) and tell me that im using to much rinse aid and salt coz we use 4 in1 tabs hope this helps smiley
Posted on Jun 13, 2008
SOURCE: Hotpoint Aquarius DWF50 Dishwasher, cycle
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Posted on Sep 25, 2008
  • 157 Answers
SOURCE: HOTPOINT AQUARIUS FDW60 ECO LIGHT FLASHING
Check pump is running
Posted on Dec 19, 2008
  • 134 Answers
SOURCE: Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Posted on Feb 14, 2009
When my dishwasher finishes it no longer lets out 3 beeps and when you open the door there is no power even though the dishes are clean.
Hello J Arnott,
Sorry to say I'm here in the USA.. and I could not easily get a similarly designed model to reveal itself (for me) to gain a better understanding of your Hotpoint LFT114... (nor could I pull a FREE copy of your user manual (without registering or otherwise exposing myself to cyber-freaks (sorry)).
Regardless of the specifics.. suffice it to day your machine is NEW enough to be quite visible and relevant...
I looked over the LFT114 HA... Display board... £42.93
(there are many LFT114
And your trouble description was quite excellent in detailing
as SEQUENCE failure of your control modules...
Although it is possible to repair these things ... it seems you have several PCBs (printed circuit boards)... replacement is usually the first best GUESS (looking at the back () side would not hurt anything)...
I have rescued many a circuit board by simply "de-soldering"...
then re-soldering a connection...
(special care, skill & tools required... not tough nor expensive).
You description and troubles indicated the beeps & lights missing: is a clear indictment of your "DISPLAY board"...
A reminder... don't touch any PCB you value without first grounding your hands (professionals use STATIC WRIST STRAPS... CHEAP (unlike circuit boards) & available EVERYWHERE).
Also... Take lots of pictures of EXACTLY WHERE every wire comes from... (look them over BEFORE you get in trouble).
Be patient & FORCE nothing.
and of course... be safe (REMOVE POWER).
Comment me back BEFORE you guess wrong... (I'll try to help) .
Spares:
Hotpoint LFT114 HA PCBs Modules
Jul 15, 2016 | Hotpoint Dishwashers
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Lft114 dishwasher does not get hot and start and wash button flash
3rd and 4th light flashing. Problem with control board. how to replace control board?
Dec 30, 2013 | Hotpoint Dishwasher Lft114uk Led On/off...
LFT114 Flashing start light and Eco wash light? Not washing but water coming in
means either Heater Open circuit or NTC thermistor detached from casing. so check resistance of heater.. if ok then pcb required...
Dec 17, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
Hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Mar 24, 2008 | Dishwashers
FDW60 Fast and Eco Lights
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius FDW60 FAULT
dishwasher runs for 1 min then stops and 40c indicator and 50c indicator flash on and off together it pumps water out then stops
Jan 03, 2008 | Dishwashers
Hotpoint 24 in. HDA3740G Stainless Steel Built-in Dishwasher Logo
788 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
