Question about NAD C370 2-Channel Amplifier
NAD C370 problem
My C370 has packed up suddenly and without warning.  Specifically, it powers up, all the buttons seem to work but the signal that reaches the speakers is 'un-amplified' i.e. one can hear a very quiet, high-pitched version of what should be coming out.(Sounds like a pair of headphones from a distance.) Have tried different sources, checked all the cabling - always the same problem.  Any thoughts.
Check the two connectors in back between the PRE OUT and the MAIN IN. Make sure they are positioned horizontally not vertically. Unfortunately, they will fit both ways and it you position them vertically, you will get exactly the problem you described. This happened to me recently after doing some repair work.
Hope this helps.
Lloyd.
Posted on Sep 22, 2008
  • 2,071 Answers
Sounds like a headphones and the power is there,of course power supply is good because there is a little sounds.This is the most common problem of the power amp.section.The solder holding the IC of that power amp.is crack you better reheat or resolder it.The cause of cracking is the vibration and temperature changing it tooks how many years that's crack comes out.The big IC there which you going to reheat is the STK IC.If nothinng improvments happen,you better change that IC,so better performance comes out,.
Posted on Jun 17, 2008
    Scholar:
  • 70 Answers
I would suggest that the fuse in the amplifier has blown. This is usually caused by a bad amplifier component (duh!).
The unusual part of your problem is that sound is being passed. When a component dies, signal stops as the continuity is broken.
Which could also suggest the power supply. Transistors work like relays, you turn on the control signal and the transistor opens or closes. It isa possible that this control voltage is not being passed.
Either way, this will require shop work
Jeff
Posted on Jun 15, 2008
NAD C370 distortion
Check first if you got +68/-68V on amp module left and right on contact CZ302 and CZ402 pin 2 & 7. Often the -68V is missing. This is caused by faulty transistor Q713 in +68/-68V power supply. It's a 2SA872.
Oct 31, 2013 | NAD C370 2-Channel Amplifier
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Dec 29, 2008 | NAD C370 2-Channel Amplifier
Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Sep 15, 2008 | NAD C370 2-Channel Amplifier
HELP PLEASE. NAD 370 JUST DIED...
This could be as simple as a bad connection at the voltage regulator IC or blown output transistors. If you have a multimeter and some experience with electronics repair, this should be fairly straightforward.
Let me know and I'll try to walk you throught the repair.
Dan
Sep 07, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
NAD C370 in protection mode
With closed eyes -replace all capacitors on protection PCB All of those caps are overheated and dry out (they lost there capacidance).Note that capacidance meter will not help you at all. Now unit will work. BUT!!! Most important!!! Check four big filter capacitors in the middle of unit!!!! If they are white (NAD 10000uF/80V) DO NOT USE UNIT AT ALL!!!! FIRE HAZARD!!!!! Contact me... Dariusz
Dariusz70@verizon.net
Feb 10, 2008 | NAD C370 2-Channel Amplifier
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
277 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
