Question about Zanussi ZWF1430W Front Load Washer
ZANUSSI ZWF1437W WASHING MACHINE
CLOSE THE DOOR PRESS START JUST KEEPS COMING UP ERROR WITH NO CODE, IS IT THE DOOR INTERLOCK THATS NOT MAKING?
  • 66 Answers
Yes sounds like door interlock cheap and easy diy job goodluck and unplug regards jason
Posted on Jun 15, 2008
Can dial in programme but when start is pressed all leds and display go out and it bleeps once. Eng mode gives E41 as last error
E41 means door open or the machine is not able to lock the door
(door delay interlock does not close after 15 seconds).
Possible causes:
door open, door delay interlock, wiring, main PCB.
Dado
May 04, 2016 | Zanussi WJS1265W Front Load Washer/Dryer
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Jun 07, 2015 | Zanussi Washing Machines
Zanussi washing machine ZWF 14581 error code 43 is showing up. How can I reset the machine so that it works normally?
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
Oct 08, 2011 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine zwf14581w . err e40
Hi.
Error 40 means : "Door Error"
When you get error 40 it is usually because of a defective door interlock.
Try disconnecting power for five minutes. If the error comes back the parts to be tested are door interlock, wiring or main PCB. The defective part must be replaced. Parts and quote on repair can be obtained contacting Zanussi customer service at the number listed on the owners manual.
Regards.
Ginko
Aug 20, 2011 | Zanussi W1042W Front Load Washer
E20 error
There is a problem with the machine interlock system
The interlock for the machine sends an error to the motor control unit if the door lock relay is not closed before a wash. Probable cause is that the door lock unit is faulty. Check if the machine closses the door before it indicates the error
Oct 03, 2010 | Zanussi IZ161W Front Load Washer
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Fjs1225w machine wont start
If its not the door interlock then the only other possible thing is the control module has failed ....
it does happen on zanussi machine.. is it making a cliicking noise the door interlock.... when you press start .... like click click....
if so then most likely its the control board inside the machine
Jan 20, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
253 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
