Question about Dryers
Kenmore Dry Model Number 110-70602990
Dry will not heat up, repairman came out and ordered lent assembly. I received part and a phone call from repairman, cheaper for me to install, only two screws. Installed part, still no heat.
  • Archie Ferrarini
    Archie Ferrarini May 11, 2010
    Kenmore Dry Model Number 110-70602990 doesnt come up as good model #,Can you re check it?
  • 868 Answers
Sorry I found it.Ok check 2 things first.#1 Heating Igniter (coil) #2 thermal fuse .
Posted on Jun 14, 2008
Old dishwasher, lock on light blinks all time
Is this a Kenmore? If so here is Searspartsdirect. User and installation manuals, parts diagrams and parts lists and repair help.
KENMORE Dishwasher Parts Model 66515817990
Oct 26, 2014 | Kenmore Dishwashers
Why won't my Kenmore dishwasher display work properly?
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
My kenmore HE diswasher, model number 665.1312 won't dry
is your heating element was working?,if working check the blower if working too.
Jun 04, 2010 | Dishwashers
No heat from dryer model kenmore 11062702102
Make sure that your vent is clean of lent. If your vent clean, then it is your element.
Nov 24, 2009 | Kenmore Dryers
We have a Kenmore 110 6092299 90 Series dryer. The motor still runs - but no hot air, at all. I've tried timed and heat dry. Nothing. It just tumbles and it takes 4-5 rounds to dry. At first we were told...
Sounds like the heating element or the thermo-cut off. A vent being clogged for some time, can cause too much heat to build up and make the element or cut off fail. These are the 2 most common things.
May 05, 2009 | Kenmore 63942 Dryer
Can't find model #86880100 anywhere on the parts sites.
you have to put the 110. in front of the model number, eg 110.86880100 <!-- from fixya rte -->
Apr 05, 2009 | Kenmore Dryers
I have a lady kenmore dryer it doesn't dry the clothes their is not even heat to dry them.
okay ASSUMING is electric and the dryer operates normally otherwise, you have a bad heating element.Most are not that hard to replace and finding one online is relatively easy if you do a search for the model number or even serial number. If you have basic electrical and mechanical skills and a multimeter to ensure power is off to the unit and that the breaker used for the cicuit isn't compromised you could probably get this done with an expense under $75.00 usually. Check the exhaust ducting to ensure it is not restricted as well.
If your unit is a gas model and the element needs replacing call an experienced repairman.
Hope this assists you.
Sep 03, 2008 | Dryers
No heat
if this worked before then the heating coil is bad., make sure the airways are clear of lent
Dec 12, 2007 | Kenmore Elite HE4 Electric Dryer
Dryer does not dry
The suggestion from barnsleymick gave us some good direction in fixing our Kenmore SmartHeat Quiet Pak 9 HE 4. We discovered our vent pipe was clogged with a great deal of lent and a quart or two of water. We cleared the vent of the lent and water and the dryer is now working like a champ! Thanks for the direction.
Sep 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
132 people viewed this question
Top Dryers Experts
