Washing machine - DWS-800WPS Error LE showing
  • 15,935 Answers
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Nov 05, 2010
DAEWOO WASHER DWF-800WPS machine the outer water is countune going out what is the problem
pump is running and not stopping, low water sensor is not working properly, replace part. it is behind control panel .
Jan 11, 2015 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Error message " LE "
Click the link below to troubleshoot the LE error on your daewoo washing machine:--- http://technoanswers.blogspot.com/2011/06/le-error-on-daewoo-washing-machine.html ----------- This should help.Thanks.Helpmech.
Jun 01, 2011 | Daewoo Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
LG washing machine problem.
LE is a locked motor error
make sure that all your connections are secured
Dec 29, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
