Question about Epson NX400/SX400/TX400
Hi there...wonder if you can help answer this question I have with my printer Epson SX440. We have it for over 2 yrs now though hardly used it has started to give poor quality print the past week when we see line across the face of the prints. That to me as a layman is the ink has not been regularly distributed across as such that the line was produced due to no ink on that line. Can you tell me what you think the problem is? It appears there is sufficient ink at cartridges... appreciate your help! Simon
    Problem Solver:
  • 13 Answers
Hi .
I am assuming when you say your printer has hardly been used over two yearsthat you never changed the ink cartridges.
If my memory serves me right Epson inks have a shelf life before drying out or the heads on the carts clog and this causes what you describe...
To Test this
Go into CONTROL PANEL...>....PRINTERS and FAXES.......There you will see your installed printer
Epson SX440 ..>.. Right click on your printer Icon, and then left click PROPERTIES
.This should bring up a dialogue box with 5 or 6 tabs...The default open tab should be General....Look near the bottom of the open box and you should see a button with PRINTING PREFERENCES.Click this box.
You should now see 3 Tabs in a new pop_up box. The one you are looking for is maintenance . click this tab.
You should now be in the right area to check for problems 1st. start the Status Monitor ,this will show you ink levels and display them for you.If these look okay try the nozzle check utility. This will print a series of lines on paper for you to check against an onscreen image..
If there are problems ,run the Head Cleaning utility. This will run the print head back and forth over a cleaning pad in the printer..After one or two of the cycles run the nozzle check again .
This sounds like a long drawn out process but i can assure you it is very simple as the software does the work, just follow the onscreen instructions and you won`t go wrong.
NOTE: due to age and lack of use of the printer I would advise you get a new set of inks ,Compatible inks are not expensive on ebay and other online stores.
Hope this helps and if there are any more problems just do a follow up post
Posted on Nov 06, 2010
I am not getting good color on my print out
Are you trying to print photographs on plain paper? Epson WorkForce printers are designed for fast office-type printing, not photo quality printing.
If you use photo-paper (specifically, Epson photo paper), and "best" quality setting, it should be better. Your color may not exactly match what you see on your screen, though. Welcome to the wonderful world of "color management".
Apr 15, 2015 | Epson WorkForce 310 All-In-One InkJet...
Hi I replaced my black ink cartridge in my Epson DX4450 a little while ago with a Tesco equvilant,now it is telling me that black needs replacing,I know its not empty as it has hardly been used.I have...
I had an epson radio once AM it was a great vacuum tube set.
I had an Epson Dot matrix it also was great.
I figure the name sold when I bought a color epson printer.
It was good until I left it sit.
It cloged up from not being used often enough.
\I bought new ink dispensers since the heads are part of the machine and not set as a cartridge head...
I ripd it all down and tried cleaning and clearing it. I finally bought a new printer and it sits and it is reliable even if I do not use it that often HP...a little over 7 yrs old
Aug 23, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Epson do not recognizing new cartridges
Just posted this answer somewhere else...you probably touched the little green microchip on the cartridge. The oils in your hand prevent the printer from reading the cartridge. Hope this helps, sucks that you may have to buy a new cartridge though!
Aug 05, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson schematic (e511 error)
Hi-
Try reseating all the toners, as well as the photoconductor unit. If all fails do a reset using the panel. Call manufacturer for 562-276-4382 for step by step instruction.
Hope this helps
Oct 10, 2008 | Epson ACULASER CX11NF All-In-One Printer
No ink = useless machine???
It should not need ink to scan / fax/ use the card reader. it just wont print :)
please rate
Thanks,
Nick
Sep 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
I want to add my cx3200 epson printer to my pc have lost the cd rom disc
Download these two drivers in order and install, follow prompts to know when to connect printer.
Printer Driver
ftp://ftp.epson.com/drivers/epson10453.exe
Twain Driver
ftp://ftp.epson.com/drivers/epson10573.exe
Hope this helps
Thanks!
Feb 27, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Colour of prints
Is it only the photos? Or do documents print poorly too? http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=35361&prodoid=41764278&infoType=Downloads&platform=All Above is the Epson site. You should try downloading and installing new drivers. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Computers & Internet Logo
406 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
