Question about Dehumidifiers
Hi, I have an Amber Dry dehumidifier which is switching itself off with a 'warning' light coming on after around 10 minutes of being on. The tank isn't full and so i can't work out what's wrong with it - also can't find the manual anywhere online so no idea what to do! Thanks for your help.
3 Suggested Answers
  • 4736 Answers
SOURCE: My Danby dehumidifier leaks out
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
Posted on Mar 23, 2011
  • 4736 Answers
SOURCE: Our dehumidifier isn't draining into tank
Daniele, the drain hole or drain hole tubing, that that flows thru to the bucket may be clogged. To loosen & remove the clog, do the following:
1. Turn the Master ON/OFF Switch to OFF & unplug the unit.
2. Remove the bucket from the unit.
3. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though).That's appropriately sized to fit into the hole or tube. Carefully insert the Zip Tie in to the drain hole or tube and continue to insert it until you reach a bend in the tube. You must gingerly work it past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Slowly pull it back out while rotating (twisting) it, This will help dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
Completing the above, should dislodge any clogs and water will start draining back into the tank. Be sure that you have the humidity extraction level set on 35%, after you turn the unit back ON.
Posted on Jul 05, 2011
Beeping tank warning light blinking, pump light not on
I think this means your pump is not working, and therefore the tank is full. The pump could just be switched off, could have failed, or could be clogged. See the other messages regarding this model, for an excellent description of how to clean out a clogged pump.
Oct 02, 2014 | DeLonghi DE500 Dehumidifier
I have a DeLonghi DNC65 dessicant dehumidifier about 4years ol. It runs for about 2-3minutes then the alarm light comes on and then it switches off. It is operating in a room which is 15 deg. C. Is this...
Ignore the first comment, Desiccant dehumidifiers do not have Freon, or a compressor...
The warning light coming on after a few minutes could be one of a few things (but probably most likely due to overheating or the detection of something not right in the unit operation. Most likely faults include:
1) failure of main fan motor (this would cause eventual overheat)
2) failure of heater blower motor (this would cause an overheat)
3) clogged desiccant wheel (restricting air flow and causing overheat)
Generally the warning lights only come on if an overheat occurs, If the heater has failed these units usually continue to run, albeit cold, and with no water being extracted.
Another culprit could be the water level cut of switch being faulty.
Feb 05, 2014 | Dehumidifiers
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    Dehumidifer will not turn on. An E2 code comes up on the panel. Has been working fine for 4 day.
    Since it has been working well for 4 days, it may be a case that the unit needs to reset itself. To accomplish this, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that timeout allowed the unit to reset itself. Also, check to make sure that the water collection bucket is installed properly and is making good contact with the safety switch.
    Hope this helps you solve the problem.
    Apr 27, 2011 | Haier 45-Pint Dehumidifier
    My unit stopped working after less than 1 year . It will occ start up dor a few secs and then stop again??
    The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
    If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
    Good luck
    Aug 15, 2010 | LG LHD45EL Dehumidifier
    My dehumidfier runs for about a min and then stops running
    If you've emptied the tank and the unit still stops running after a min, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
    Take care.
    Aug 12, 2010 | Goldstar DH304 Dehumidifier
    My dehumidifer kr923317 283w will not come on it just beeps
    Good luck.
    Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
    The red indicator light just flashes when i turn the unit on. Whats wrong?
    Good luck.
    Aug 12, 2010 | Kenmore 54351 Dehumidifier
    My dehumidifyer won't continuously run
    HI,
    Take care
    Aug 11, 2010 | Whirlpool Dehumidifiers
    Newair ADS-300 Dehumidifier
    Nov 12, 2008 | NewAir ADS-300 Dehumidifier
    Dehumidifiers Logo
    269 people viewed this question
    Top Dehumidifiers Experts
    Bill Long
    Gil Shultz
    jasbo
    jasbo
    Are you a Dehumidifier Expert? Answer questions, earn points and help others
