Question about ViewSonic VX924 19" LCD Monitor
Blinking monitor hey there! my monitor started to blink today for the first time, it happened after inserting a usb memory stick to print some document. since then it did not stop blinking, it usually happens around every 10 to 15 sec or so and it goes off for about a sec or 2. any suugestion will help. thankyou p.s the motto about the fish was great.
  • kabyle Jun 20, 2008
    more publicity than the actual help
  • ViewSonic Master
  • 12,061 Answers
Ok well I think ya have a Power Supply problem with ya Monitor...
But to be sure try it on another PC see if problem follows, if NOT then maybe ya Video card is starting to bug out?
But I punt for the PSU in the Monitor.. As an aside check the Pins inside the Monitor connector see they are all OK
Posted on Jul 28, 2008
I bought a 2gb memory stick for my psp, once i insterted it in an orage light keeps blinking and while i put it on usb mode it says there is no memory stick insterted when there is
If the MS light keeps blinking continuously, that means that the PSP cannot read the MS you inserted. That happens normally. You just need to take it out, then put it back in. That's the simple fix there.
To pull it out, open the MS slot first. Gently push the exposed part of the MS, inward to pop it out.
When putting it back in, make sure that it's perfectly aligned and that the light blinks fast only for a couple of seconds (2 to 4sec) and then immediately stops. That means, the MS is properly placed and can now be read.
May 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
How to repair psp memory stick and never stop blinking
Take it out for a second and insert it again. That's the only fix for that. Keep trying until it read properly.
Apr 22, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
The psp says, no memory stick inserted and everytime i insert it, the orange light just blinks continously! please help its 4gb and expensive!
I had this problem. 1 day it was working then it wasnt. Re format it in windows as NTFS then move it to your psp and reformat it there. Hope this works for you
Feb 01, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My psp 3000 cant detect my 8GB memory stick
try connecting it computer and do a virus quarantine and some times i also see this problem when u insert a memory stick the orange light will only blink and when you go to any option you get that it is empty first do this take out the memory stick and put in the memory stick and while putting the ms to the psp kepp pushing the ms to the psp then you will see the orange light blinking and after the blink stops take your hand off and that will be OK
Dec 24, 2009 | Sony PlayStation Portable (PSP) Console
Memory stick unreadable by psp
try formatting the memory card via a card reader..
thats all i can think of
good luck!
May 30, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
USB not saving audio. It gives CPU out of memory error.
Don't have too many folders on a flashstick try keeping everything into four folders maximum and I think you'll find it works perfectly.
Good Luck
Dec 21, 2008 | Peavey 32fx USB 32 Channel Mixer
Monitor blinks out for 2 seconds
What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
May 29, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Help me with my digital camera! pleaseeeeee
Hi there, please purchase (or borrow) the new memory stick in order to check whether the old one is OK. When you try the new memory stick, please give me the feedback info. Best regards, Arpi
Apr 15, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
ViewSonic VX924 19" LCD Monitor Logo
164 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
