SOURCE: Is my LaCie External USB 2.0 500GB fried/dead???
Does it make any clicking/clunking sounds like any of these?
If yes - it's really bad and there's nothing you could by yourself..
If it sounds normal or doesn't spin up at all then try to remove it from enclosure and connect directly to a PC.
SOURCE: LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
SOURCE: trouble seeing my lacie drive possible mounting issue
It sounds like the RAID controller in the LAcie drive may have failed. When this happens generally the data on the drive is left intact but you will require a new casing for the drives and the help of a data recovery pro to get the files off before you can re-initialize the set. Unfortunately all the good free/cheap utilities work only on single drives so you will need the help of a pro with high level software and additional equipment to retrieve the files.
If you are in North America I would recommend Armor-IT Data Recovery, they're listed in the FixYa service database for most US states. If you're outside North America, post your location and I will help you find an appropriate service.
Chris
SOURCE: PC no longer recognises LaCie drive
Hi Katya!
There are several possible causes for this. You didn't specify if you're running Windows or Mac so I apologize in advance if some of the information I provide does not apply.
I do hope I was able to solve your issue. I wish you the best of luck.
Greg
