Question about Lexmark C500n Laser Printer
LEXMARK C500 My Lexmark C500 printer comes up with the warning 'Replace Toner C' when the toner is getting low.I know from experience that the toner lasts for ages after the first warning and is a waste of money replacing it at this early stage. I can get it to work without replacing the toner by opening and shutting the printer door but it goes through a lengthy warming up routine and this happens with every document. Does anyone know how to by pass the warning ? Is there a hidden menu somewhere which would disable it?
  • Anonymous Mar 15, 2014
    lexmark c500 toner cg error
  • Anonymous Mar 31, 2014
    reset after replaced
If you open your printer front and pull out all the toner cartridges, on the left, you will see 4 LED lights vertically in a column that match up with 4 matching red light receptor sensors on the right side. Each toner cartridge has a tiny window on each side. When the toner powder level drops below the window level, a light passes all the way through the cartridge from the LED light to the light receptor and trips the printer to display the low toner warning.
The goal is to BLOCK THE LIGHT. The easiest way is to put electrical tape over the window on the right side of each cartridge window. To ensure you have the proper hole, just shine a flashlight in the hole and you will see the reflection from the tiny plastic window.
Posted on Nov 16, 2008
I found a fix for this! Take the cartridge out. On each side of it there is a hole (I believe that this is a sensor...) place a small piece of electrical tape over these holes. Place cartridge back in.... no more error! But I would go out and get some toner soon though!
Posted on Oct 30, 2008
  • 197 Answers
Nope..none that exists..that warning is based on approx 20% of the ink remaining
Posted on Jun 14, 2008
PC life warning on Lexmark e360dn
You need to change the photo conducter... its the 2nd tray that pulls out under the toner cartridge I think its a green handle same as toner
Jul 27, 2012 | Lexmark E360DN LASER PRINTER N Laser...
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
TONER LOW
Your toner (ink) in the printer is running out. You should be replacing it soon.
Details on how to replace the toner cartridge are on the link below:
http://support.lexmark.com:80/lexmark/index?page=content&locale=EN&userlocale=EN_US&id=HO2339
Apr 12, 2011 | Lexmark T640 Laser Printer
My Lexmark E250DN : 02 led on the right hand is ON, the system restart and can not print. Any suggestion for help???
You can press and release Continue button to clear the light sequence and continue processing the print job. Turn the printer off and remove the toner cartridge, and shake it to extend the life. If toner light is on, replace the toner cartridge.
For further assistance, please call Lexmark Technical Support.
Jan 11, 2011 | Lexmark E250dn Laser Printer
I get a toner low message with the Lexmark X342n when the toner keeps working for a few more months???
Depending on how much you use the unit it could. If you are a casual user and do not use it everyday I would not see why it would not. I have had toner cartridges which give the low toner warning and they last for years. The other thing you can do to extend the use of the cartridge is to remove it periodically and rotate it end to end and side to side. This will redistribute the toner across the roller and allow you to print good copies. If you don't do this the toner gets trapped in some areas and you could be throwing out a cartridge with alot of copies left in it. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 13, 2010 | Lexmark X342n All-In-One Laser Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
Replace toner
Please click here and the installation guide to install the toner cartridges ..
Good luck..
Nov 11, 2008 | Lexmark C912 Led Printer
Lexmark C500 printer SVC LL ERROR, SVC L1 ERROR
As i'm sure you already know the error means - Laser power is lower than the output limit.
It's probably due to a bad contact on the engine board. If you would like the service manual it can be downloaded from the following link free of charge http://www.eserviceinfo.com/equipment_mfg/Lexmark_22.html any problems come back to me.
Aug 11, 2008 | Lexmark C510n Laser Printer
Lexmark C500 Error light showing,with New ink cartrige inserted showing toner low replace cartrige on machines display? Help!! thanks
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Jul 02, 2008 | Lexmark Office Equipment & Supplies
Lexmark C500n Laser Printer Logo
485 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
