Question about Sony KP-51HW40 51" Rear Projection Television
Projection tv problem lens
Hello, how are you today? i need your help , i have a old sony rear projection TV, now i have having problem , on the rear projection tv , the lens have 1 type of lique now is leaking, but i cannot buy the rubber seal , can you pls let me know where can i buy? My tv model is : KP-E53MN11.
last, looking forward your reply soon
Thanks
Thomas ( Brunei )
  • 927 Answers
Good Day;
Hey, Thomas;
As you stated very few companies provide the rubber seals.
The best thing to use is silicon, place it where the seal is. Remove the CRT from the unit, drain the fluid, clean area, replace with Ethylene Glycol. Make sure you let the silicon to set up, about 24 hours.
Good Luck, Day, Big Irish.
ps call if problem at mmrkcar@yahoo.com.
Posted on Jun 18, 2008
I have a sony wega 2004 lcd 42" lamp light blinks red when tv is off no pic when tv is on. what does this mean?
This TV is garbage! Finally through mine out in the garbage - replaced the lamp cost from $100-300 - both lamps exploded - replaced optical block twice - lens very distorted - plain old garbage! I will never buy sony products again especially since I paid 4,000 for this tv it was new tech at the time and I was desperate for a tv - sad I am!
Jul 19, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
Dark Picture on Sony KP-51WS510
Maybe need sort of ajustment of the projection inside. clean the circuit and resoldered all parts maybe some loss connection in the circuit board. becarefull of high voltage that can hurt you.
may this help, melnavz
Apr 15, 2008 | Sony KP-51WS510 51" Rear Projection...
Blue cloud
That's OK, I been provided you technical info about TV problem.
Jan 31, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Fluid in len leaks out
Hello grace11112,
First I have to say that the fluid is what keeps the tube cool, if you use the TV without replacing the fluid, the tube will eventually burn out. Now the fluid has to be replaced, I would suggest that you have a qualified TV technician do this. The fix for this problem is to reinstall the seals on the tube refill the coolant, and reinstall the tube. Coolant can be purchased from the manufacture or from a parts supply store.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 08, 2009 | Sony KP-51HW40 51" Rear Projection...
SONY PROJECTION TV (42 inch)
most sure your tv is getting sick, just kidding
probably convergence problem you may need to call a tv tech
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KDF-55XS955 Rear Projection TV
This is a problem with the AKB circuit. Are you comfortable working with TV circuits? Can you solder? If so, please update this and I'll look up the most likely parts late today and post them for you.
Dan
Mar 18, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Shadows on Rear Projection TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Televison & Video
Sony Projection Model# KF-42WE610
how old is your set?. This TV uses A bulb for its light source...(LCD Projection). If your tv is a few years old, and has over 4000 hours of use on it...your bulb may be on it's way out. The first sign of the bulb getting weak is loss in brightness of picture. Also make sure you vaccum the back of the set regularly, as there are fans to keep the bulb system cool, and if the fans and vents get full of dust, the bulb won't cool as well leading to premature failure.
Dec 29, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Warranty TV
call a tech to correct your problem your lens might be your problem out of alignment.good luck.
Apr 01, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
