Question about Garden
Have new hitachi chopsaw, need blade for laminate flooring
    Brigadier General:
  • 4,088 Answers
The blade that you need is carbide-tipped, many-toothed with the proper center-bore diameter. A chopsaw is usually used for cutting steel parts and not particularly precise for flooring. Good luck!
Posted on Nov 05, 2010
When cutting 7.5" laminate wood floor with 12" miter saw. When we cut, the very end of wood(1.25"at the same place on every piece). Does this mean blade is dull?
Hi Shaun:
Just a couple of things to try:
- Make sure the laminate is supported at both sides when cutting.
- Make sure the laminate is held firmly against the fence and deck when cutting.
- Do not "rush" the cut. Laminate is very hard and does not like to be hurried.
- Make sure that the correct blade (teeth) is being used.
- And yes, the blade has to be SHARP
Jul 25, 2015 | Saws
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
My motor Boggs down
This can be caused by a dull blade. Installing one laminate floor is enough to dull a new carbide blade.
Apr 06, 2014 | Festool Kapex KS 120 EB Sliding Compound...
Laminate Flooring
Need more information.
Read our guide on laminate floors
Jan 23, 2014 | Hampton Bay Building Materials
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
Can I install laminated floor in my bathroom?
Laminated floors can be used in any room you would like although there are some laminated floors that are more sensitive to moisture. If you want to use laminated floor in your bathroom you will need to prevent water from core material of the floor.
For how long do I need to wait after I installed my laminated floor?
Glue-less laminated floors can be installed fast and are able to be used immediately. Glue laminated floors need to set for 18 to 34 hours before being walked on.
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
Garden Logo
29 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
