Question about WYSE WINTERM 9150SE
Lost bios password which was the serial and dont have it is there a way to bypass
    Genius:
  • 1,456 Answers
Hello
First, remove the case to look at the motherboard, so we can try resetting the CMOS battery. This battery looks a shiny little disk the size of a nickel. Pry the battery free gently, and reinsert the battery after 10 minutes. If this worked and you don't see the password prompt, you don't need any more steps; the problem is fixed. In my experience, two or more additional steps might be necessary depending on the make of the BIOS. Unfortunately, they don't all respond to the same tricks.
Next, now that the case is already removed, locate the jumpers near the edge of the board or near the CPU or the CMOS battery. Once located, find the label that will say clear CMOS, or clear password, etc. Place the jumper over the pins and boot. If this works, no more steps are needed. If it doesn't work, read on.
The third step to try is to enter a password. When you receive the password prompt, try one of the following passwords. If you have an Award BIOS, try these; AWARD PW, ALFAROME, or _award. If you have Phoenix BIOS try, CMOS, PHOENIX, or BIOS.
If none of these things have worked, as a last resort, try a software utility that resets system passwords. These utilities can be found online.
Posted on Nov 05, 2010
Tip
How to Bypass BIOS Passwords
If you are unfortunate enough to set a password for your BIOS password for PC and forgot it, chances are you may need to send it back to the manufacturer. Not to worry yet, you still can try out some tips and tricks to bypass or unlock the BIOS password:
BIOS passwords can add an extra layer of security for desktop and laptop computers. They are used to either prevent a user from changing the BIOS settings or to prevent the PC from booting without a password. Unfortunately, BIOS passwords can also be a liability if a user forgets their password, or changes the password to intentionally lock out the corporate IT department. Sending the unit back to the manufacturer to have the BIOS reset can be expensive and is usually not covered in the warranty. Never fear, all is not lost. There are a few known backdoors and other tricks of the trade that can be used to bypass or reset the BIOS password on most systems.
on Jul 14, 2010 | Computers & Internet
Tip
BIOS passwords can add an extra layer of security for desktop and laptop computers. They are used to either prevent a user from changing the BIOS settings or to prevent the PC from booting without a password. Unfortunately, BIOS passwords can also be a liability if a user forgets their password, or changes the password to intentionally lock out the corporate IT department. Sending the unit back to the manufacturer to have the BIOS reset can be expensive and is usually not covered in the warranty. Never fear, all is not lost. There are a few known backdoors and other tricks of the trade that can be used to bypass or reset the BIOS v Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself. They include:
Using a manufacturers backdoor password to access the BIOS
Use password cracking software
Reset the CMOS using the jumpers or solder beads.
Removing the CMOS battery for at least 10 minutes
Overloading the keyboard buffer
Using a professional service
Please remember that most BIOS passwords do not protect the hard drive, so if you need to recover the data, simply remove the hard drive and install it in an identical system, or configure it as a slave drive in an existing system. The exception to this are laptops, especially IBM Thinkpads, which silently lock the hard drive if the supervisor password is enabled. If the supervisor password is reset without resetting the and hard drive as well, you will be unable to access the data on the drive.
----------------------------------------------------------------------------------------------------------- Backdoor passwords
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops.
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords
Award BIOS backdoor passwords:
ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222 589589 589721 595595 598598
AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
MISC. COMMON PASSWORDS
ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
OTHER BIOS PASSWORDS BY MANUFACTURER
Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba
TOSHIBA BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot ---------------------------------------------------------------------------------------------------------- --------------------------------------------------------------------------------
P
on Jun 25, 2010 | Computers & Internet
Hp 2560 bios password forgotten
Try this:
http://lmgtfy.com/?q=forgot+bios+password
There are heaps of results including this one:http://www.technibble.com/how-to-bypass-or-remove-a-bios-password/
Dec 19, 2012 | HP 2560p i5 2450M 12 5 500G 4G
How do i unlock my bios password?
You would need to remove your keyboard where the bio's flat battery is located. Take that battery out for 10sec, then put it back in. That will reset your bio settings and password
Mar 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
I forget my laptop bios password ,so how can i remove password
I found a homepage with a load of Backdoor passwords, - one of them will bypass you forgotten BIOS password. If you dont know your type, you´ll have to try them all out, or untill you hit the right one:
http://www.computerhope.com/issues/ch000451.htm
Good Luck
dont forget to vote me.
Jan 22, 2011 | Lenovo Computers & Internet
Lost bios password
Pull the CMOS battery (the round thing) off your motherboard for 15 minutes, then put it back in. It should clear out your bios password.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
Sep 30, 2009 | Packard Bell Computers & Internet
Forgot bios password
does your laptop have a 25 pin serial port?
Jun 27, 2009 | Toshiba (P000191710) for T4850 Sound Card
Password retreval or bypass
f you need to bypass the BIOS password - assuming that this is a desktop pc, you need to remove either the BIOS battery from the motherboard or switch the bios reset jumper to another position for a while and then back, I can help you more with that if you first clarify is this a bios password or not and then is the computer a laptop or a desktop pc.
Jul 19, 2008 | Computers & Internet
WYSE WINTERM 9150SE Logo
428 people viewed this question
Top WYSE Computers & Internet Experts
Daniel
Daniel
Brett Duxbury
Brett Duxbury
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
