Question about Sony Ericsson Walkman W810i Cellular Phone
PHONE DOES NOT DETECT THE MEMORY CARD - Sony Ericsson Walkman W810i Cellular Phone
  • 943 Answers
This could be caused by a damaged memory card or a damaged memory card slot on your phone. the steps to take is this,before you do this, remember your phone cannot read any memory card above 4gb and in most cases it wouldn't even read more than 1gb..so if you are trying a bigger size, that could be the cause but if not, proceed below
1.try the memory card on another compatible phone or on a sony psp and see if the device detects it and if it does, the problem would be coming from youjr phone and not memory card.
2.trying using another memory card of the same type on your phone and see if it works out well for you.
3.try pulling out the memory card and see if there is anything like dust particles on the golden panel of the memory card(avoid touching the golden panels) try using a soft brush that is not wet with any liquid or lightly soaked in methylated spirit to clean the surface of the golden panels ensuring the liquid does not gain accces into the plastic casing.
after this, try using it again and see if it works.
hope this was of help to you?
Posted on Nov 05, 2010
My micromax q5fb mobile cant detect memory card
Hi
Now use the simple trick to detect the memory card, because in china phone no safely remove option. so while remove the memory please switch off the mobile and while putting the memory card you have to again restart you phone otherwise it can't detect. try this trick may solve you problem.
God Luck
Sep 09, 2011 | Cell Phones
NOKIA 2700C MEMORY CARD NOT FORMMATED SHOW PC NOT DETECTED MEMORY CARD WHAT CAN I DO PL HELP
Use a card holder to connect the memory card to the PC and if this is not detected check it out on another PC. If not detected then the card is defective. If not you can right click and format the card after removing all the files from the card.
If the card is not detected it is damaged and you can try if there is a free replacement from the dealer.
Sep 05, 2011 | Nokia Classic 2700 Cell Phone
I have a blackberry curve with a 2gb memory card but now when I want to access the memory card it shows there is nothing on but I have music and pictures on the memory card
Hi
Firstly check whether u have inserted memory card correctly . If that is correct then check whether the phone is detecting the card. I think blackberry has an option to check it .
If the phone is detecting the card then check for the free space it is showing on the card . If it is showing the correct space and not showing the contents then switch off and switch on the phone after removing the card .
If the phone is not detecting the card then check the card using a card reader there also if it not getting detected then you need to check the card whether it has some physical problems. If the card is getting detected on the card reader check your phone with some other card and even after that if the same situation exists then you can take your phone to a service center
Oct 27, 2010 | Electronics - Others
Memory card no dedect,and no files in displade.
Hi,when a memory card does not detect on phone, it simply because the the memory card you inserted into the phone is not properly fixed or the memory card you inserted into the phone is damaged,that's when if doesn't detect the memory card on the phone.
You can insert the memory card inside a card reader or a friends phone that uses the same memory card type to confirm if the memory card is not damaged yet.
I guess that will solve the problem.
Take care.
Oct 11, 2010 | Sony Ericsson G502 Cellular Phone
Samsung SGH L 170 cannot detect memory card
First, try using a known working memory card into your Samsung phone. Or, insert the undetected memory card into another phone so that you could isolate the problem.
If the phone did not detect the known working memory card, then, you need to contact the manufacturer of the phone for repair.
There's a possibility that the memory card slot of your phone is no longer working correctly or they just need to replace some components.
Good luck and have a great day!
Jan 28, 2010 | Samsung Cell Phones
I did a reformat but still my phone cannot detect the memory card
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
please rate this advice if it helps...tc! :)
Sep 24, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
My phone is not detecting the memory stick micro
Format the memory card in pc or any other phone then insert in your phone it will work.
Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Cannot detect my 4gb memory card
First you should format your 4gb card with your phone software so that itll create the file system.
then your phone will detect the memory card
Aug 06, 2009 | T-Mobile MDA Compact Smartphone
Formatted memory card of nokia N72 not detecting in the phone
See if the phone detects a different memory card. If it doesn't detect any cards at all, try to reset/update the phone firmware.
If that doesn't work the card slot might be damaged, maybe dust and dirt?
Feb 04, 2009 | Nokia N72 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
115 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
