Question about Garmin eTrex GPS Receiver
GPS displays BNG on location
After mapping a site on Etrex Garmin GPS i got BNG on location where i expected co-ordinates of site. Pls can someone assit in solving this problem.
    Problem Solver:
  • 6 Answers
BNG stands for 'British National Grid'
  1. Go to the Setup menu
  2. Select Units
  3. Change the Position Format to hddd°mm.mmm'
Posted on Jun 24, 2008
I have a Garmin etrex handheld unit. The gps data from it does not correlate with google maps gps coordinates at all. There is a 30 mile, not feet but mile difference in the waypoints. Any idea what I may...
You need to make sure your GPS unit and Google maps are using the same map datum.
In your user manual:
http://static.garmincdn.com/pumac/eTrexLegend_OwnersManual.pdf
Page 44, Setup Options, Units, Position Format: I suggest setting to:
hddd.ddddd as this is the digital format and easier to read
In Google Maps, right click - Drop Latitude/Longitude marker and this should show the co-ordinates in digital degrees. Alternatively, you can hit the SEND button in GoogleMaps, and it will send the marked location to the GPS via the Garmin website. You may have to install the Garmin plug-in into your browser first, but it's well worth it.
If this solves your problem, please come back and rate our solution, thank you.
Dec 19, 2010 | Garmin eTrex Legend GPS Receiver
Does aby know if my Garmin 1310 can use OS grd references instead of longditute and latitude? If so how is it set up?
Unfortunately Garmin satnavs do not allow OS Grid References instead of Longitude and Latitude. However if you need to find the Longitude and Latitude of a point it can be done by going to http://www.gorissen.info/Pierre/maps/googleMapLocationv3.php Zoom in on the location you want and left click on it. The longitude and latitude will appear in a box to the right of the map. You need to set the co-ordinate system of the satnav to match the longitude and latitude format of the satnav. To do this touch Where to, Co-Ordinates, Format. Enter the co-ordinates and touch next. It's not an ideal solution but it might help you out if you're stuck.
Aug 09, 2010 | Garmin GPS
I have no CD software but i want to install online software, pls
There is no software for your etrex GPS to install on your computer. You can, however, purchase Garmin maps to install onto your GPS. When you purchase this mapping software, it will include a copy of Mapsource, which is used to upload and download tracks and waypoints to your unit.
Mar 04, 2009 | Garmin eTrex Vista GPS Receiver
Entering map references manually
To enter a waypoint, either use Mapsource software and transfer to the unit, or else create a waypoint and then edit it to the proper co-ordinates.
Dec 01, 2008 | Garmin eTrex Legend GPS Receiver
Entering coordinates into a etrex yellow
Mark a waypoint, then edit the waypoint, entering the new co-ordinates.
Oct 04, 2008 | Garmin eTrex GPS Receiver
Etrex Vista HCx will not calculate routes.
Please post the co-ordinate of the starting waypoint and I'll check it with mine.
Aug 12, 2008 | Garmin eTrex GPS Receiver
Garmin Etrex - ORdnance Survey Grid reference nos
You shouldn't have to connect to a computer. I don't have an OS map in front of me but I'm guessing they use UTM with a WGS 84 datum (if the map was produced after 1984 that is). Got to the Setup page then select Units. Change Position Frmt to UTM/UPS and Map Datum to WGS 84.
Jul 29, 2008 | Garmin eTrex GPS Receiver
Grid bearing
If you press in the control stick, it will make a waypoint at your location and you can see the co-ordinates. The numbers can be displayed in various ways, all depends the settings you have used in the Etrex.
Your bearing will be on your Navigation Page.
http://www8.garmin.com/manuals/eTrex_OwnersManual.pdf
Feb 22, 2008 | Garmin eTrex GPS Receiver
No location shows
  2. Select Units
Aug 19, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
708 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
