Question about Cobra 25 WX-NW-ST 40-Channels Base CB Radio
Blows fuses This radio was installed in my Volvo truck. The computer in the truck started having issues and over-voltaged the whole electrical system. When that happened the CB shut down and has never powered back up since. The inline fuse blew so I replaced it. It don't matter if the radio power switch is on or off it still blows the fuse. I seen somewhere that there is a reverse polarity protection diode on these radios. Where is it and what is it marked?
  • Anonymous Mar 30, 2014
    now blows fuses and will not power on
    reversed polarity, now will not power on , but blows fuse
  • 126 Answers
When you open up the radio and look at the component side (top of pc board), the diode you are looking for is D17. It is located basically in front of where the PA jack connected to the pc board. Just make sure when you solder the new one in place, observe the side that the grey band is on, which should be facing toward the point of the arrow pic.
You can pick the diodes up at most Radio shacks or online through www.partsexpress.com. I use Parts Express for all of my small electrical components and tools. They are very reasonable and very trustworthy. The diode you are wanting is called a Rectifier Diode. The part numbers range from 1N4001 and 1N4008. I use 1N4007 (the only one Parts Express stocks) and it works just fine. Here is a direct link to the page with this diode http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=1N4007
They are only .09 each. I hope you get your radio back in working order.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
Posted on Jun 17, 2008
  • 27 Answers
The diode used is a standard 1amp 50 volt you can get one from almost any junked electronic device...a 1 amp 400 volt will be fine also to use
CHEERS
Posted on Jul 03, 2008
    Problem Solver:
  • 13 Answers
I have a friend who is a CB tech and when I did something like that to a Palomar amp I had, he replaced the diode in a couple mins and that did fix it. See if you can find a service manual for you make and model. It was located right by where the power lines came into the case. Make sure you install the diode the correct way. A diode is what is used to allow electricity to flow only 1 direction.
Posted on Jun 15, 2008
2000 volvo v70. Radio was left on Would not jumpstart...battery takes a charge soon as it is connected to car..smoke starts coming from either starter or alternator and if I turn key on..blows fuse
that question is not very clear, is the smoke coming from the starter or the alternator ??? obviously which ever it is , the smoke will indicate a short circuit in either the starter or alternator and this is why the fuse blows when you switch on you need first to determine if it is the starter or alternator then get it replaced or repaired.
Oct 03, 2016 | Volvo Cars & Trucks
2001 volvo v70 tailgate lock/unlock relay location. Tailgate not locking checked fuses, no sound from tailgate, however do get click sound from fuse area.
Check the wiring to the rear hatch. The cables break and cause a variety fo problems like yours. You will have to take the plastic cover off and expose the cables.
Mar 01, 2015 | 2001 Volvo V70
Subaru electrical blows fuse to computer
You really need to supply more detail. What have you inspected? Have you checked the fuses to see if there are other problems? Have you noticed any damage to cable harnesses behind the glove box or in the engine compartment?
Typically when you blow fuses, there is a ground not connected and the voltage spike blows the fuse which is the safety feature placed by the manufacturer. If you do not have electrical experience, do not try to resolve the issue yourself. Seek a professional repair center right away.
Jan 24, 2014 | Cars & Trucks
Radio amp fuse blows
problem could be radio.10 amp fuse for ignition switch power up radio display the 30 amp fuse for radio amp system in which that circuit hot at all times.
Nov 18, 2013 | 1998 Lincoln Continental
Crossed battery cables radio dont work put new fuses in still dont work
I had similar issues and it turned out to have to do with my remote start. I was going to remove the whole start system but decided on a new vehical since the damage was done.
If you dont have a remote start, the issues are electrical; ruined wires etc. I would say take it into an electrical auto shop.
Nov 26, 2011 | Cars & Trucks
MY 96 SUBURBAN 2500 7.4L SUDDENLY DIED WHILE DRIVING. AFTER I COASTED TO A STOP I TRIED TO RESTARTING BUT NO LUCK. HAVING HAD THE FUEL PUMP REPLACED BEFORE I KNEW TO LISTEN FOR THAT SOUND OF THE PUMP...
The key is to find out what is causing the ECM fuse to always blow. With just the key on try and see if any codes are set in the ECM. If not, try a new ECM. If the fuse still blows, then disconnect all accessible electrical for everything, including radios, accessories, relay boxes,etc. except the ECM. If the fuse still blows, then probably something wrong with the wiring to the ECM. If it doesn't blow then start hooking up things one at a time until it blows again. Once it blows, that is your problem.
Aug 24, 2017 | 1996 Chevrolet Suburban
In my 2000 volvo s80, the radio stop working and the door lock button and the dome lights are intermittent. I checked all the fuses and are all good.
Try resetting the electrical system by locking and unlocking the doors with your key in the driver's door 5 times in a row. A service manager at a Volvo dealer showed me this after they did some work on my car and on the way home the sunroof wouldn't close.
I have a 2001 S80 that I have to reset the electrical system like this every time I disconnect the battery. All kinds of stuff stops working...sun roof, door locks, lights, radio, windows, etc. Just reset like described and everything should start working again.
Good luck.
Sep 19, 2009 | 2000 Volvo S80
Installing a sony cd/radio (CDX-GT222)
Sounds like a possible ground issue. Check your ground (very important). Also try running the red wire to a keyed source i.e. from fuse block. Then run the yellow to a constant 12v source i.e.battery.
Jun 19, 2009 | Sony CDX-GT210 CD Player
COLD START ISSUE
try pushing the 4 wires on the radio supression relay into the connector, then try starting it... does it start, run, then die? those connectors ****, i've had the same prob. have you let it huff on some ether? (starting fluid) does it come to life? that would confirm weather or not it its fuel related. my 740 i was loosing voltage to my injectors 10 volts and under, causeing them to inttermittantly not fire, caused by a bad connection at that supression relay.
Feb 13, 2009 | 1991 Volvo 740
1989 Volvo 740 audio fuse 26 blowing
I had a friend who owns a small dealership make a call and he received a wiring schematic that showed that the radio has an external audio amp located under the dash below the steering wheel. The amp was shorted.
Dec 11, 2008 | 1989 Volvo 740
Cobra 25 WX-NW-ST 40-Channels Base CB Radio Logo
178 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
