Question about Acer Aspire 9300 Notebook
Acer aspire how do i revert my aspire 9300 to original reg settings it keeps loading in safe mode
  • Brian Gonsalves
    Brian Gonsalves May 11, 2010
    What operating system? Have you tried a full shutdown and restart?
  • 3,940 Answers
If it keeps booting in the safe mode, at the desktop it will say SAFE MODE in each corner of the screen.
If it does boot to the safe mode, click start, RUN, MSCONFIG click OK
Click the Boot.ini tab,. and see if the /SAFEBOOT option is checked.
If the screen doesn't say safe mode, then your video resolution is set too low, and adjusting Display properties and or reinstalling the video driver should resolve.
Posted on Jun 14, 2008
Windows wont load
Kindly Elaborate your issue to enable us to help you. Let me know if What exactly you see on the screen and at what point the screen stops working..
If you see the windows loading screen and it does not load try the following.
Restart the computer and keep Tapping the F8 key
You will see a screen that says Advance boot options
Select the option that says Safe mode
See if it boots in Safe mode
If you are able to start the computer in safe mode, Try to restore the computer to an earlier time when the system was working fine.
This should help you to fix the computer.
For any further assistance feel free to revert
Sep 27, 2012 | Acer Aspire One PC Notebook
My acer aspire 9300 is really slow and i wont to delete everything on it but i dont no how to how do i do it?
Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Aug 27, 2010 | Acer Aspire 9300 Notebook
Acer 9300, when I start up it last about 5 minutes before it is finished. When I reach windows acer says there is problem with your secure disk reboot your system. What can i do to solve this?
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 09, 2010 | Acer Aspire 9300 Notebook
Trying to access the cd rom on a Acer Aspire 9300
When you go to safe mode, make sure that you go to "safe Mode with Networking", that way you can access the net. To make sure you have a good connection, get a long ethernat cable and connect it directly to the back of the router, in case the wireless driver fails. Get on the net forst, then try this site for your cd reading problem.....
http://support.microsoft.com/kb/314060
Oct 14, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 turns on with black screen
Hello!!
Try entering thro the safe mode ... and restore the system. let me know the updates.
Cheers!
Jun 23, 2009 | Acer Aspire 9300 Notebook
My acer aspire 9300 doesn't go on. Screen black. Electrics are fine. What to do- I am running Windows Vista Home Premium.
Recent hard ware or software change might have cause this. issue
try using the F8 key while computer starts and try to log on to safe mode and do a system resotre or you can choose the option last known good configuration
May 08, 2009 | Acer Aspire 9300 Notebook
Boot up cycles, windows appears, but reverts back to boot
It may just be a default setting in the new BIOS. Enter the BIOS setup and check the SATA mode - I've seen this occur with the ACHI mode for example. Otherwise you could try Safe Mode and see if you can get into Windows at all. You can also press F8 while booting and select the option to Disable Automatic Reboot so that you can see the Error that is occuring for further diagnosis.
Feb 14, 2009 | Acer Aspire 9300 Notebook
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
Aspire 9300
Run 'sysprep -factory'
the above application can be found on a Windows XP installation cd-rom under support and inside deploy.cab which can be extracted using windows.
google 'sysprep -factory' for more information.
Jun 14, 2008 | Acer Aspire 9300 Notebook
Acer Aspire 9300 Notebook Logo
279 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
