Question about Acer Aspire 9300 Notebook
Aspire 9300 how do i revert my aspire 9300 to original reg settings
    President:
  • 169 Answers
Run 'sysprep -factory'
the above application can be found on a Windows XP installation cd-rom under support and inside deploy.cab which can be extracted using windows.
google 'sysprep -factory' for more information.
Posted on Jun 16, 2008
  • virtual_a
    virtual_a Aug 29, 2011
    I think the asker means "how do I set mu aspire 9300 to riginal regional settings", rather than "how do I restore my apire 9300 to original factory settings".
    So if the first answerer's advice was accepted, the asker now does have the original Regional Settings but has also wiped all his/her data as well.
    Control Panel > Regional & language Settings > select country settings from drop menu adding preferred regional settings with "Add" and removing undesired ones with "Remove" > change settings in all 3 Tabs - General, then Languages - Details OK > Advanced > Apply > OK
    This is for archive purposes, in case someone reviews old posts looking for answers.
My acer aspire 9300 have beep code: 1 long and 2 short in start up..
This beep code is -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
This is most likely a video problem.
Try re-seating the RAM, the video RAM is shared, uses part of the main RAM.
Also try restoring the BIOS setting back to the default settings.
Mar 03, 2011 | Acer Aspire 9300 Notebook
Tip
Revert back to original settings done by the registry
paste following code in Notepad ans then save it with name “regdefault.reg” (including quotes). Then run the file and your settings will be reverted back to original:
Windows Registry Editor Version 5.00
[-HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\Copy To]
[-HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\Move To]
[-HKEY_CLASSES_ROOT\Directory\Shell\DosHere]
[-HKEY_CLASSES_ROOT\Drive\Shell\DosHere]
[HKEY_CURRENT_USER\Software\Microsoft\Notepad]
“StatusBar”=dword:00000000
“fWrap”=dword:00000000
[HKEY_CURRENT_USER\Control Panel\Desktop]
“AutoEndTasks”=”0′
“HungAppTimeout”=”20000′
“MenuShowDelay”=”400′
“WaitToKillAppTimeout”=”20000′
“LowLevelHooksTimeout”=”20000′
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
“NoLowDiskSpaceChecks”=dword:00000000
“ClearRecentDocsOnExit”=dword:00000000
“NoRecentDocsHistory”=hex:00,00,00,00
“LinkResolveIgnoreLinkInfo”=dword:00000000
“NoResolveSearch”=dword:00000000
“NoResolveTrack”=dword:00000000
“NoInternetOpenWith”=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control]
“WaitToKillServiceTimeout”=”20000"
on Jun 03, 2008 | Compaq Presario 700 470024-192 Notebook
My acer aspire 9300 is really slow and i wont to delete everything on it but i dont no how to how do i do it?
Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Aug 27, 2010 | Acer Aspire 9300 Notebook
How do you put acer aspire 9300 back to factory settings full destruction?
press ALT + F10 button as soon as PC startup and run recovery console from there. follow the steps to restore PC to factory settings.
Jun 15, 2010 | Acer Aspire 9300 Notebook
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
Acer 9300 aspire resolution problems.
Hi, Thank You For Choosing FixYa!!!
If you Wish. I will take remote Control of your computer and I will try to Fix it.
Thanks, PREM
Mar 13, 2009 | Acer Aspire 9300 Notebook
Boot up cycles, windows appears, but reverts back to boot
It may just be a default setting in the new BIOS. Enter the BIOS setup and check the SATA mode - I've seen this occur with the ACHI mode for example. Otherwise you could try Safe Mode and see if you can get into Windows at all. You can also press F8 while booting and select the option to Disable Automatic Reboot so that you can see the Error that is occuring for further diagnosis.
Feb 14, 2009 | Acer Aspire 9300 Notebook
Acer aspire
If it keeps booting in the safe mode, at the desktop it will say SAFE MODE in each corner of the screen.
If it does boot to the safe mode, click start, RUN, MSCONFIG click OK
Click the Boot.ini tab,. and see if the /SAFEBOOT option is checked.
If the screen doesn't say safe mode, then your video resolution is set too low, and adjusting Display properties and or reinstalling the video driver should resolve.
Jun 14, 2008 | Acer Aspire 9300 Notebook
Aspire 9300
Have you tried new drivers for the graphics?
Nov 14, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 9300 Notebook Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
