I have a old pc a person came and put a new hard drive in and he must have put the welom sign in i dont want it i preferd end user
If you are using windows go to the control panel and then go to personalize or it will check the setting in the user accounts....try looking I have been using windows 7 for a while and have forgotten where a lot of things are in windows 98 and xp if i think of it I will definetly post for u
Posted on Nov 05, 2010
I put in a new hard drive it says the same thing dell ******* sucks parameter has exceeded its normal operating range
The hard drive may be failing, or just the OS or hard drive corrupted. You could try this... Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good luck.
Jul 26, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
Want to wipeout memory on my pc
To "Wipe your memory" I have to assume you mean your hard drive. You will need a disc that has a Format function on it. It is easiest to use a Windows disc to do this. Just put the disc in the cd/dvd drive and wait for the format request to come up. If you just want to remove all of your personal data, The easiest way is to create a new "Administrator" account in the control panel under "User Accounts" then log into that account and delete your user account. This will remove your personal data.
Nov 03, 2012 | Dell OptiPlex GX260 PC Desktop
I want to clear my hard drive, because I'm giving my computer to someone
You don't really want to clear your hard drive unless the person you are giving it to has an operating system to reload, otherwise the computer is useless to them. What you really want to do is get rid of all of your documents, music, pictures and videos. Here's what you should do. 1) Click Start/Control Panel/User Accounts and select the option to create a new account. Give the new account the name of the person you are giving the laptop to with administrative rights (not a limited account) or give in a generic name such as Owner or User. 2) Once you've created the new account do a restart of your computer and when it comes up log in to the New Account that you created. 3) Now click Start/Control Panel/User Accounts once again, but this time select your old account, then look for the option to Delete User Account. 4) Delete your old user account and delete all associated files when asked. It will take a few minutes but when finished all of your documents, music, pictures and videos will be long gone and your user account will be gone also. Now when you give the computer to the new owner it will be operational and he can start using it.
Mar 14, 2012 | Dell Computers & Internet
My sony Vaio VGC-RB53 wont boot at first i got a message of a fan problem on CPU, i replace the CPU for a new one with more watts and by the way put a new hard drive on it (1T). I was on the process of...
Almost sounds like your wizard ended up coping everything to your new hard drive. And when you do this usually it causes the copied system to not boot. What you need to do is put your old hard drive in the system and make it the secondary drive and then get the new hard drive and make it the primary hard drive. When you do this you need to install Windows from your Operating System disc if you have one. Once you do this you can put all then needed data from your old hard drive onto then new one. Usually the one and only thing people need on the old hard drive is the documents and settings folder it will usually have everything you have ever saved to your computer unless you have things elsewhere like directly on the c drive instead of on the desktop or in your documents. If you need further assistance don't hesitate to reply.
May 29, 2010 | Sony VAIO VGC-RB53 PC Desktop
Will not boot. I haer slight clicks out of the hard drive
it sounds like a faulty hard drive.replace and reinstall operating system
Sep 19, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Jun 22, 2009 | Panasonic Computers & Internet
Can't locate music & photos on an old hard drive
I created a program that finds music files.
It will probably be useful for you.
http://rapidshare.com/files/236925438/Find_My_Music_1.0.0.exe
Any questions contact me at QuackWare@gmail.com
Jan 14, 2009 | i-rocks External Hard Drive Enclosure -...
Hard drive dont load up properly
your hard drive is dead mate. sorry. they die form time to time.
buy yourself a new hard drive and an external hard drive caddy (a 3.5" one) make sure the caddy is the right connection for your old hard drive. either sata or ide.
then put the new hard drive into your pc to take the place of your old one, and load windows onto it.
next get your old hard drive into the usb haddy drive caddy/enclosure, connect it all up and see if you can use the ghost function on norton anti-virus secruity to bring back your old data.
hope this helps.
kev
Oct 02, 2008 | Acer Aspire T310 PC Desktop
I had a computer crash I bought a new computer and put the hard drive from the old one as second
yes it is working but I cannot see any of the admin files... I can see the user files.
Any suggestions?
Mar 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
David Payne
David Payne
