Cars & Trucks Logo
Posted on Nov 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove the oil pan gasket from my 1999 Cadillac Deville Concours
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 289 Answers
  • Posted on Nov 05, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
289
Questions
Helped
73900
Points
783
Answer is.... You will not be able to remove the oil pan with out ruining the oil pan gasket. You may want to buy a new gasket and a about 4 cans of oil before you start. There is a drian plug in that vehical for the engine oil. Not the tranny. Go to a place like PetBoys and get the gasket first, and the oil!. Keep in mind you may want to make sure the oil pump pick up filter is clean' Once you drop the pan you will see the pick up for the pump.
Hope that may help you.
I'm looking for votes. If my info. was helpfull please vote with all your 4 thumbs.
Thanks
ASH
Duane Wong
Level 3:
  • Cadillac Master 6,826 Answers
Duane Wong
Cadillac Master
Level 3:
Answers
6826
Questions
6
Helped
2861564
Points
20234
Oil Pan REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the crankcase.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Oil level indicator harness connector, if equipped
    • Exhaust Y-pipe, if needed
    • Transaxle assembly from the vehicle.
    • Oil pan bolts and the oil pan
    To install: NOTE: The oil pan gasket is reusable unless it is damaged. Do not remove the gasket from the oil pan groove unless gasket replacement is required.
  4. Thoroughly clean the inside of the oil pan and the cylinder block contact surface. If the oil pan gasket is being reused, be careful not to damage it. Do not expose the gasket to cleaning solvents.
  5. If a new gasket is being installed, start the gasket into the oil pan groove and work the gasket into the groove in both directions. Once the gasket is exposed to oil, it will expand and no longer stay in the groove without wrinkles. If this condition exists, replace the gasket.
  6. Install or connect the following:
    • Oil pan. Torque the bolts, in sequence, to 89 inch lbs. (10 Nm).
    • Oil level indicator connector, if removed
    • Transaxle assembly, if removed
    • Y-pipe, if removed
    • Flywheel cover, if removed
    • Oil pan drain plug. Torque it to 15 ft. lbs. (20 Nm).
  7. Refill the crankcase.
  8. Run the engine and check for leaks. Fig. 1: Oil pan bolt torque sequence How do I remove the - 7922vg08.gif
  • dvnimp Dec 06, 2010
    This was very helpful because I started the process and then realized that I had to removed the transmission pan to complete the task so I stopped working . I talked to the dealer ship
    and it will cost $ 1400 , guess what I am going back to work . Thanks Duane
Blown head gasket and oil pan leak in a 1999 cadillac deville with 85,000 miles...what should i do?
if you can repair it yourself have a go .if not then way up the cost of a garage repair to see if its worth keeping or trading in
How do I remove the dash in my 1999 Cadillac Deville Concours?
http://www.ehow.com/how_7794388_remove-dash-2000-cadillac-deville.html This will show you how to remove your dash. If you have any more questions please let me know. And please leave good feedback.
3helpful
How to replace oil pan gasket on 2002 deville
  8. Run the engine and check for leaks. Fig. 1: Oil pan bolt torque sequence 7922vg08.gif
1helpful
I want to know how change my oil pan gasket.
The oil pan gasket is a complex task. Due to the design of the Northstar engine,ie the exhaust crossunder exhaust pipe either the engine has to be removed from the car or remove the transmission.... The oil pan is a two piece assembly. Upper and lower. Yhank you
Oil pan gasket fell out...
3500.00 cadillac dealer ...motor has to come out
How do I change the oil gasket??
Are you talking about the oil pan gasket, valve train cover gasket? Id so on either one you must remove the old gasket an replace it. You can try tightening the bolts some to see if that stops the leak, but if not, the gasket should be replaced.
Coolant leaks, oil pan gaskets leak started
Check temp control sending unit and thermostat.
3helpful
2answers
Engine overheats after i had radiater put in
do me a favor and pull the sparkplugs out get a compression gadge and do compression tests on all the cylinders they should be within ten psi of each other if not yes you have either a cracked head or a blown head gasket
Oil leaks
after a period of driveing you have to get oil pan re tighting some times improper installion can keep it leaking also.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
