Question about Dishwashers
Dishwasher Please help amber light on in neff dishwasher but no neff technique line open
  • daveydave43 Apr 07, 2009
    same: amber light next to 'arrow between two lines' symbol
  • 1,036 Answers
Hi there.
Check salt and rinse-aid levels first. Often there is an indicator if either of these falls below a level.
When was the last time you filled them?
Top up rinse aid to mark, and add at least 1kg of salt.
Run M/c on a quick cycle and see if it's back to normal.
Hope this helps you.
Posted on Jun 14, 2008
Hi I have no lights on my Neff s51m53xogb dishwasher. I have checked power supply at the plug and to the machine and all are ok. Please help???
If you are sure power is reaching the unit it may help to remove the back panel, (make sure everything is disconnected first)!,
inspect in for water ingress and rust. Sometimes a rusted or dirty Earth can cause these problems.
Leaving it open for 24hrs may help, also blast some air in from a compressor if you can.
Aug 07, 2015 | Neff Dishwashers
My neff dishwasher is not filling with water
Water inlet valve is responsible for filling water in your dishwasher, when that goes bad either the dishwasher wont fill at all or will fill the water slowly. Please check the inlet screens and also try to clean the water lines for any clogs/obstructions. Please get back to me if you have any other questions.
Nov 11, 2010 | Neff Dishwashers
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher will not turn on, power check done, please help
this looks like a power supply problem if you are sure you are getting power right up to appliance it can only be a electronic failure pcb open circuit etc anything else and the lights would still illuminate.
Jul 25, 2009 | Neff 24 in. S5444X1GB Built-in Dishwasher
Neff Dishwasher (end of cycle) - beeps all night
Yes the beep tone is variable down to nothing.Suggest downloading manual from Neff website in pdf form for instructions.
Jun 09, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
Jan 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
No water going into machine
may be the electric valve on the incoming water line is broken or too low water pressure, may be also the program knob is faulty or the cpu does not give signal for the electric valve to open when u select the program
Jan 08, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
you have a draining problem ... check the garbage disposal that it is clear.. then check your drain hose and the the drain trap inside your dishwaher....
if all this don't help then go to the drain pump ... hope it helps
Jun 14, 2008 | Dishwashers
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwashers Logo
251 people viewed this question
Top Dishwashers Experts
