Question about Toastmaster Breadmaker's Hearth 1193 Bread Maker
Price of paddle and baking bucket - Toastmaster Breadmaker's Hearth 1193 Bread Maker
    Genius:
  • Toastmaster Master
  • 1,280 Answers
Here is a website for parts. based on what I see here you may be better off buying a new or used machine with a good paddle and pan.
http://www.vendio.com/stores/breadmakerguru/category/1193/catId=3449206
I have some toastmasters for sale, let me know if you are interested.
Posted on Nov 05, 2010
Kneading paddle bakes into the bread
Kneading paddle on EVERY breadmaker usually bakes into bread. Let the loaf cool and then gently remove it. Or use the dough setting and cook bread in the oven. (i do this) delicious!
Jul 05, 2017 | The Kitchen Appliances - Others
I need a manual for my Breadmaker as I have lost the instructions
Bread Machine Basics ' Hillbilly Housewife
www.hillbillyhousewife.com > Frugal Living
Apr 22, 2009 - These previously owned bread machines seldom have their manualincluded. .... On my machine the White Bread or Basic Cycle takes 3 hours.
How to Use a Bread Machine: 10 Steps (with Pictures ...
www.wikihow.com > ... > Recipes > Baking > Breads
wikiHowInside the bread machine, there is a bread pan or bucket. ... The bread bucket works as both the mixing bowl and the baking pan. In the center of the bread bucket will be a little bread paddle or kneading blade.
Nov 23, 2015 | Kitchen Appliances - Others
Is the paddle supposed to spin
Your paddle won't turn. Your silver bucket is the one moving (turning) and not the paddle. It's working like it should. I thought the same before I found the lid (cover).
Jan 11, 2013 | Back to Basics -- Plastic Bucket Ice Cream...
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Kitchen Appliances - Others Logo
42 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
ellenskitche
Steve Allison
Steve Allison
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
