Tv daewoo clear picture. but no sound, when use to dvd plater audio video ok
  • Televison & ... Master
  • 17,130 Answers
Possible that the SIF- sound intermediate frequency section- is faulty.lt must be checked with a audio signal trace from the VIF/SIF sections to the preamplifier.
Since your AV is working and the DVD works fine , this section can be faulty.
Posted on Nov 05, 2010
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
Pioneer pro 506pu plasma
Connect the dvd playr to the pioneer thx and connect the tv to the pioneer thx.
Dec 15, 2013 | Audio Players & Recorders
No sound
It could be the software you are trying to run the DVD with. Check the software against other DVD's. If not it could be your audio drivers or audio codec.
May I suggest http://www.videolan.org/vlc/index.html for watching videos.
If it is an audio codec issue try this.
http://codecguide.com/
Jan 17, 2013 | Toshiba Computers & Internet
I have sound but no picture on the screen.. What did i do wrong
Hello sir, hi, please check the video cable. If you are using the three color audio/video cable, the yellow one goes to the yellow input of the TV to the yellow output of the DVD recorder. Then check the TVs audio video settings, the TV should be in the video channel, if there are several video channel, check where the video is coming in. Make sure that the yellow cable is good. you can swap several cables to check.
If your TV is component input, put the red green and blue wires to their respective color port, one end is on the DVD recorder, and the other on the TV. make sure your cables are good. Do the same thing with the S-video and HDMI cable. if your TV has this.
Nov 21, 2009 | Daewoo DVRS05 DVD Recorder/VCR
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
My dvd player has no audio sound at all daewoo dvd player perfect picture but no sound any ideas
is the connectors ok?try swapping your connectors.are you using a stereo amp?connect your rca plugs to ML and MR for stereo.check the audio settings of the DVD just to be sure.
May 31, 2009 | Panasonic DVD-S52 DVD Player
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Nov 22, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
