Question about Apple iPod nano
My iPod Nano Died And I Just Bought A New USB Cord And It Wont Charge Or Turn On...It'll Just Show A Little Apple For 2 Seconds Then Go Back To A Black Screen...How Can I Fix This.!?
  • 3,530 Answers
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Cheers!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jul 03, 2011
Ipod wont turn on
There are several reasons why your iPod Nano may not turn on or awake out of its "Sleep Mode." This can be extremely irritating if you wish to use your iPod Nano, but the device is constantly malfunctioning. You may not need to take your iPod Nano in to be repaired if the player doesn't turn on as normal. There are a variety of different fixes that you can attempt as a way to get the Nano to turn on.
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano. Hope this helps.
Jan 22, 2013 | Apple iPod nano
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
Some sweat fell on the wheel and the ipod turned off. when i tried to charge it it got very hot it still wont turn on
Did the ipod show any symbol while it was on charge. Sometimes, the atmospheric temperature & humidity of surrounding area makes the device hot even after a few minutes of charge. if this is the case then
1. Remove any jacket/covering/sleeve of your ipod. 2. Connect to power outlet or usb for charging however make sure it is as far away from pc/laptop as possible and in a breezy area. 3. Charge for 15 minutes. 4. Hold down the menu and middle button for 30 seconds until the apple symbol appears.
In case there is a problem with internal circuitry, the ipod will show one of its distress symbols.
Aug 19, 2009 | Apple iPod nano
2GB nano wont charge
Check this first. Both computers have USB2. Both computers are awake. iPods will not charge from USB1 or when the computer is asleep. Check the computers and cord is ok by plugging in another iPod. If the iPod is still under warranty, Apple will replace it.
Apr 29, 2009 | Apple iPod nano
Ipod nano 8GB 3rd generation FROZEN!
Try resetting the ipod while its connected to the computer by holding both the menu and center button at the same time for 6-10 seconds until you see an apple appear on the screen. You may need to repeat the reset. If this fails your looking at a hardware issue most likely. Good Luck.
Apr 19, 2009 | Apple iPod nano MP3 Player
My ipod wont turn on or charge.
More than likely the battery just needs to be replaced. I let my nano go dead and it was doing the same thing. So just get it replaced and that should fix your problem.
Mar 23, 2009 | Apple Audio Players & Recorders
Ipod help!!
Do you have an IPod charger that plugs into an elecrical outlet?
See if you can charge the battery that way.
You could try another USB port.
Jun 16, 2008 | Apple iPod nano 3rd Generation
Help me pleeze
Make sure that your iPod’s hold button isn’t on. (little switch at the top left corner of the iPod). If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod screen. If you see either of these, move the switch back and see if this fixes the problem. If that doesn't fix it:
Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart it. You’ll know it's restarting when the Apple logo appears on-screen.
Jan 10, 2008 | Audio Players & Recorders
Ipod nano
you need to download itunes from the apple website
Nov 28, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
