TV Samsung LE40R73BDX/XEU VERSION SP01 attached to SKY HD via HDMI cable Worked with no problems until now. Displays the message .... This display does not support HDCP disconnect HDMI conection. Stops working with PS3 also
  • beecroft98 Jul 11, 2008
    i have the same problem with the le40r73bdx
    sky been working fine for a year and a half now just get message saying tv is not hdcp compliant.
    also ps3 not worrking and dvd hd not working.
    everything else on the tv works perfectly.
    any fixes for this problem?
  • Anonymous Jan 01, 2009
    I HAVE THE SAME PROBLEM PS3 HD AND BLU RAY NOT WORKING, HOWEVER I DID NO GET ANY WARNING JUST STOP PLAYING PS3 HD.
SOURCE: 1080p high def issues
The HDMI cable I had originally wasn't a good enough quality. I purchased an HDMI v1.3 cable and everything works at 1080p. You don't need to pay loads for a cable, got mine from Play for £9.99.
Posted on Jun 03, 2008
SOURCE: Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Posted on Dec 31, 2008
  • 11800 Answers
SOURCE: DVI alert, Your HD tv does not support HDCP,
Antipiracy warning , cannot be disabled or bypassed, it's a part of your tv. Because of it you will not be able to use the DVI connector to view blu-ray movies. You will have to use the Component (YPbPr) ones , at a much lower image quality.
Posted on Mar 20, 2010
Testimonial: "cool"
SOURCE: Samsung hl61750a - unable to display video service over hdmi
restart the att cable box by unplugging the power cord.
Posted on Jul 02, 2010
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
Connecting PC with HDMI port 1 to watch NetFlicks. Wonderful picture. No sound from TV. Only get sound from PC. PC HDMI sound test works, but not able to hear movie?????
Posted on Apr 06, 2011
How do I get my PS3 to work over hdmi?
Try swapping out HDMI cable. The version of cable. (1.2, 1.4 etc ) might be too old/faulty for PS3.
If your Tv is HD ready and not Full HD lower the video quality in the PS3 settings
Aug 06, 2015 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung sp01 is undetectable through PC HDMI I am
This could be as simple as a defective HDMI cable. Have you tried connecting anything else with this cable? Have you tried another HDMI cable?
Oct 21, 2013 | Fujitsu Siemens LifeBook® C1410 PC...
LG 37LC2D-EC
It sounds like the TV is having sync issues with your Sky+HD box. HDCP is the "High-bandwidth Digital Content Protection" that is used between components. It requires a sync between the devices to ensure that you are not trying to "steal" the video content you are watching. This intermittent message and blacking of the screen is good evidence that this is your problem.
Even though the HDMI cable worked fine on another set, I'd try a new one anyway. Some TVs and components are more sensitive than others, and a weakened cable may not show a problem on one set, yet show it on another.
Barring the new cable not working, check LG's website for a possible firmware update for your TV, and also try using a different video source, like BluRay and see you have the same problems.
Beyond that, it may just be an issue with the TV itself starting to die.
Sep 15, 2012 | LG 37LC2D Television
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
Upgraded Sky+ to Sky +HD, but I now have a messages saying this display does not support HDCP?
Yes your tv is hdcp compliant.
This may not help but often when this message comes up it is the hdmi cable you are using. I do not know whether or not you are using an hdmi to dvi cable or an adaptor or and hdmi to hdmi connection. The cables available for purchase at beachaudio.com are not expensive but they usually work when you need to try another hdmi cable because of this particular message.
Mar 03, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Tivo HD displays ''hdmi connection not permitted''
This happened to me many times with my Sharp 40" LCD. I am actually running 2 tvs of of 1 HD Tivo. One in the bedroom with HDMI and then through the wall into my kitchen tv via Component. ( yes whatever is on in the bedroom plays in the kitchen).. So this AM my power dropped out for a few seconds then came back on. When the Tivo rebooted I got that " hdmi connection not permitted" message. In the past, I would just reboot everything and all would be ok.. But today I couldnt get the tv with the HDMI to display the programming. It would show the tivo menus, but when I tried to play anything or watch live tv, the message would pop up again. The kitchen TV with the components was working the whole time...
So finally I rebooted the Tivo one more time. But this time I left the HDMI cable unplugged from the Sharp in the bedroom untill the Tivo was fully booted and a live channel was playing in the kitchen. I then plugged the HDMI back into the bedroon TV, and it came back on. Im not saying this will work for you, But its worth a try
Mar 08, 2009 | Televison & Video
I have a new HP Pavilion dv5t notebook (purchased 10/23/08). I can play regular DVD and Blue-ray DVD's on it with no problem using the HP QuickPlay software installed on the PC. I can also connect the...
This is a security feature of the High Definition Content that it does not allow veiwing of any high def content on dual displays.
There is a very simple fix to it...
Go to Nvidia control panel..
Select setup multiple displays..
Choose the option Single display ( one display at a time ).
Thats it.. This should enable you to play the blue ray dvds on the external display.
Regards,
Anup
Jan 01, 2009 | HP Pavilion dv7-1130us laptop
Mar 29, 2008 | Televison & Video
Televison & Video Logo
637 people viewed this question
Top Televison & Video Experts
