Question about HP Compaq Presario v3000z Notebook
How to solve physical memory dump - HP Compaq Presario v3000z Notebook
  • Sebin Punnacheril
    Sebin Punnacheril Nov 05, 2010
    Are you referring to a memory dump in any programing language?
  • 857 Answers
To solve your problem follow these steps :
Boot into safe mode and perform a system restore
Turn off you computer and when you turn on next time press f8 doing this you will get windows advance boot options.
Select safe mode and press the enter key twice this will boot your computer in safe mode.
Once you boot in perform System Restore to a date when your computer was working fine.
To do system restore follow these steps :
in xp :
click on start - all programs - accessories - system tools - system restore
In vista or win 7
click on start
in the search window type system restore
you will get the system restore window in the window select a date as a restore point when your computer was woriking fine
this will automatically restart the computer and finish the processyou just need to follow the screen prompts.
Once you are done with this you can also perform memory diagnostic test
to do it follow these steps :
1.You can Open Memory Diagnostics Tool by clicking the Start button , clicking Control Panel, clicking System and Maintenance, clicking Administrative Tools, and then clicking Memory Diagnostics Tool.‌ If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2.Choose between the two options for when to run the Memory Diagnostics Tool:
•You can restart your computer and run the tool immediately.
•You can restart your computer and run the tool later.
You can perform a clean boot
To do it check this link :
http://support.microsoft.com/kb/929135
You can also download a cleanner to clear the junks and bad registry entries
the best is to download CCleanner for free of cost.
to download click on the link below
www.cclner.notlong.com
you can use the registry cleaning utility and also do a jun cleanup by clicking on run cleaner.
This must help you.
Posted on Nov 05, 2010
  • 386 Answers
Hi Good day!!!
Check your Memory (RAM) turn off your laptop and then remove your Memory then clean it same use a brush for cleaning.
I am sure you freak out when you computer screen suddenly turns blue and you see the error message that says "beginning of physical memory dump".
What do you do? Most people would just reboot the computer and pretend nothing happens. Some people want to know what happened and what they should do to fix it. It can be very daunting and stressful when you get the blue screen of death while doing important work. You would not have time to save it because it happens suddenly without any warnings. You must do the work all over again after rebooting.
What actually cause the physical memory dump?
  • DLL error
  • RAM Hardware Problems
  • Memory allocation error
  • COM error
  • HIVE crash
What should you do when it happens?
If it occurs because of your memory problem, then you should consider buying a new computer.
The ignorant way is doing a reboot and hoping that it does not happen again. The hard way is to address what caused the error and fix it manually. If it occurs because of your chaotic registry, you could find and fix it, which is very dangerous because one simple mistake can lead to a total error in your system. Reinstall your operation system might be a wiser decision to make.
The easy way is to pay a computer technician hundred of dollars to fix it for you. But in fact you could do what the technician would do to fix your computer; the wise way is to be a computer technician yourself. Did I said that you could actually do what a computer technician would do to fix your computer? Yes, it is very simple really. A technician uses a simple software to fix your registry.
If you could be the technician yourself and pay less to get the software that you can use forever, why should you pay a technician hundreds of dollars to fix it only one time for you?
You will want to do regular maintenance to keep your PC error-free so that this problem never re-occurs again.
Thank you for using FixYa
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
I am using win7 in my pc.and i have a problem that dumping physical memory&restart my pc.how can i solve it?plzzzzzzzzzz help me.thanks in advance......
dumping of memory is a bad memory stick remove one at atime reboot when problem stops thats bad stick,ps all could be bad
Feb 02, 2011 | Computers & Internet
My toshiba satellite M55-S135 is showing a blue screen with "physical memory dump complete" & to contact tech support. Basically, wanted to ask if my laptop is crashed...
Hi:
Crashed is a generic term, and the physical memory dump error is a windows based error that could be a bad memory stick, or a corruption in windows. If you have 2 sticks of memory in your laptop, a cheap and easy way to troubleshoot this would be to remove one stick, then the other,to see if one stick removed stops the crash. If it does, then you have solved the problem, and if it doesnt' then you have a corrupt software issue.
Hope you get a cheap fix!
Jan 18, 2010 | Toshiba Satellite M55-S135 Notebook
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Beginning dump of physical memory
Try removing that newly added memory and see if it solves the problem. Might be faulty or incompatible.
Jun 28, 2009 | Compaq Computers & Internet
This could be pretty complex. The ATAPI.SYS file controls the Hard Drive and CD-Rom Drive. I would recommend reading this MS TechNet article:
http://support.microsoft.com/kb/822051/ The article says that it's not uncommon for the problem to be caused by faulty memory or by problems in the mass storage controller subsystem, which makes sense since atapi.sys (a mass storage controller system file) is noted.
If you have multiple memory cards in the machine, it might not be a bad idea to take one out and try again. If the fails, keep swapping out memory cards until we either solve the problem, or elimite that as a cause.
Apr 21, 2009 | Computers & Internet
Fysical dump memory happens when I download torrents, every minut
first do defragmentation then increase ur virtual memory, if not solved then reinstall your operation system might be a wiser decision to make.
Mar 21, 2009 | LanReady LA1000+ Network Adapter
Physical dumping of memory
Hi!
Take out the RAM and clear the fungus..
fix the RAM and start with safe mode....
Bye & Take care...:)
Mar 13, 2009 | Microsoft Computers & Internet
Problem of physical memory dump
physical memory dump occurs when more than 1 program try to occupy same space in RAM.
Actually there are many products available in the market for this.
i just recommend you to download and install trial version of IOLO SYSTEM MECHANIC and run it on your pc.
this will solve your problem
Sep 13, 2008 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
HP Compaq Presario v3000z Notebook Logo
356 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
