Question about Yahoo Messenger
After uninstalling the yahoo messenger, i can't re install it? can you tell me the reson?
    President:
  • 2,291 Answers
Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Posted on Nov 05, 2010
I cant see text when chatting on yahoo messenger, please help me to fix this problem
Go to start button, control panel, Programs-uninstall programs. Click Yahoo Messenger. Click uninstall. Then go to http://messenger.yahoo.com/download/ and re-instal the latest version following all instructions. If it still does not work after that, you may need to install some updates for flash players, but the Messenger instal will tell you that this is the case, and will direct you to where you can get those updates/programs.
Mar 29, 2011 | Yahoo Messenger
I have down loaded yahoo messenger but when I sign it it tells me my application is not found
Try removing Yahoo messenger, from teh control panel, and then reinstall it again.
Mar 04, 2011 | Yahoo Messenger
As i sign in to yahoo meggenger,it suddenly disappear,plz tell me the solution. iam the permanenet of yahoo messenger user.
Dear go to the control panel and uninstall yahoo messenger after that use Reginout to fix your registry errors then install yahoo messenger and have fun.
Regards
Jay
Jan 03, 2011 | Yahoo Messenger
I need to uninstall yahoo messenger. Please tell
How to remove Yahoo Messenger in window XP: To remove a program that is installed on your computer, follow these steps: Click Start, click Control Panel, and then double-click Add or Remove Programs. In the Currently installed programs box, click the program that you want to remove, and then click Remove. If you are prompted to confirm the removal of the program, click Yes.
How to remove Yahoo Messenger in window Vista:
Click Start, click Control Panel, and then double-click on Programs or Programs and Feature. In the Currently installed programs box, click the program that you want to remove, and then click Uninstall. If you are prompted to confirm the removal of the program, click Yes.
Feb 12, 2010 | Computers & Internet
Please help me either fix yahoo messenger or tell me how to get rid of it completely i tried to uninstall it it wont let me
if you cant remove it from add remove programs, you can try to use window installer cleanup utility. you can download it from this website : http://support.microsoft.com/kb/290301 . if it doesnt work you can use CCleaner and download it from this website : http://www.filehippo.com/download_ccleaner/ . to run windows installer clean up utility,after you have successfully installed it on your computer, it should show up on all programs after clicking start button. now you cna look for yahoo mesenger and click delete. if you want to use ccleaner here is a screenshot of the tools window, http://www.ccleaner.com/screenshots/tools-uninstaller
look for yahoo messenger and click delete entry. after using ccleaner, restart the computer and uninstall it as well using add remove programs. you can also uninstall yahoo messenger following this path: my computer/local disk c/program files/yahoo/ and then delete the folder that say messenger.
Sep 26, 2009 | Yahoo Messenger
If i double click the icon yahoo messenger will not come on or if i uninstall it will not do it
I suggest you download Ashampoo-UnInstaller from http://www.download.com/Ashampoo-UnInstaller/3000-2096_4-10032301.html
and try to uninstall yahoo by this software and then re-install your yahoo messenger, I hope it fix.
But if this software couldn't help you, I suggest you to delete yahoo messenger manually (goto C:\Program files) and delete Yahoo messenger folder manually and try to re-install your yahoo messenger.
Good luck
Feb 25, 2009 | Yahoo Messenger
My yahoo messenger wont open so i try to uninstall it but it dosnt run it says CANT OPEN INSTALL.LOG. so what should i do? tnx....
Fastest way to fix this is to reinstall the same version of Yahoo Messenger by just running the installer again, uninstall, and then get a new version. Tell me if you need more help.
Feb 01, 2009 | Yahoo Messenger
I need experienced help to uninstall yahoo messenger will not unt
try installing it and then uninstall it !
if it doesn;t work than manually remove it (should be in Program Files\Yahoo\Messenger... i think ...)
Jan 07, 2009 | Yahoo Messenger
Yahoo Messanger Install Problem
Step 1: Uninstall the Yahoo Messenger
Step 2: Go to Run
Step 3: Type REGEDIT
Step 4: Delete the Yahoo Messenger and try re-installing it again.
Regards
Nov 27, 2008 | Yahoo Messenger
Signing on to yahoo messenger 900-2034.
try uninstall again the yahoo messenger select complete uninstall, remove also backup data if system ask and after uninstall complete go to C:\Program Files\Yahoo! folder and delete Messenger folder, remove also in recycle bin, restart your computer and install yahoo messenger again. I suggest to install the Yahoo Messenger Full Standalone Installer, you find this at google search.
Nov 18, 2008 | Yahoo Messenger
Yahoo Messenger Logo
15 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
