Question about Cameras
SD Cards What do es it mean? Micro cards, mini cards, card only, card with adapter or something like that. Please explain. Thanks very very much.
  • 10,594 Answers
These words like micro-mini shows physical size of memory cards, means small size cards.
card with adapter means card will be placed in adapter and now adapter will be placed in card slot.
Posted on Jun 14, 2008
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
Nov 26, 2013 | PNY 1GB microSD Memory Card
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
I want to reformat my sandisk micro mini sd card using my verizon lg
You can't, fdisk on Android phones has had that ability removed. Buy an usb to micro mini card adapter and format it on a computer. Much easier.
Dec 12, 2012 | Electronics - Others
Hello, I have bought an adapter micro sd xd adapter for an old finepix f10 photo camera. I have tried more micro sd card 2GB, 4GB, 8GB with this new adapter, but is is not working in my finepix f10. It...
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Jul 21, 2011 | Cameras
My hp officejet 7210 all in one will not read my SDHC memory card for my new Panasonic camera. Why? Should I purchase just a SD memory card? Will that work?? Thanks
Purchasing an SD card might be better. Just for the fact that when your printer was manufactured the technology for SDHC cards were still not incorporated in your printer.
Feb 06, 2011 | HP Office Equipment & Supplies
I have just been given a kodack easyshare c143 camera as a gift but i do ot have a memeory card di i ned to purchase one before i can use it ?
For all practical purposes, yes. The camera does have some memory, but you probably won't be able to take more than three full-resolution pictures before it fills up.
The C143 uses SD and SDHC cards. I strongly suggest buying at least two cards so as to have a spare in case you fill up one card or one card goes bad.
Jan 03, 2011 | Cameras
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
Memory stick too small for my printer
Sounds like you are using an incorrect memory card, or you need to get an adapter to allow your card to fit your printer. Check the printer specs to see what type of memory the printer reads, then find the adapter to change your memory card to that spec. Good luck
Jun 14, 2009 | SanDisk 2GB microSD Memory Card
Can I transfer pictures from my computer back to my chip
If you have a micro SD card that has an adapter for your computer you can plug it into your computer and open it inside an explorer window and drag and drop pictures from your computer folder to your picture folder on the micro SD card. You can definitely do it. I just did it for a friend of mine and it works perfectly. That's why they sell the micro SD cards with the adapters for your computers...so you can transfer things back and forth. Mine is the 8GB Kingston that comes with adapters from micro to mini to regular SD card and to USB port. I bought it from Newegg.com for under $20.
Nov 27, 2008 | LG VOYAGER VX10000 Cellular Phone
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
