Question about ASUS P4SP-MX Motherboard
3 beep error
I have a problem with setting up the bios. After i have flashed bios revision 1006 beta i tryied to install XP. After setup copied the files to hard disk first reboot has the problem and bios is sounding 3 beeps. I suspect the problem could be with hard drive. I had sam problem with revison 1005. Somehow i managed to fix it ones, this time i can not.
  • astralsys Jun 14, 2008
    Still 3 short beeps. But, when I inserted boot cd for XP before it started did say NO EMULATION. I pressed ENTER it continued setup for XP instalation. After copying of files to hard drive, there was reboot. The system runs. It shows PCI listing, and then the last massage on screen was:
    Update ESCD Successfully
    This is where i have three short beeps and the system holds!
    I have Intel processor 2.4 GHz
    Novelist:
    Champion:
  • 210 Answers
If they are short beeps then power off and reseat the memory boards, if you have more than one memory board and the problem persists then try reseating one at a time and power on, then try the other one.
Cheers
Posted on Jun 14, 2008
How to update bios
To find the current BIOS version, follow the steps below:
  1. Restart the computer and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  2. Write down the BIOS revision number from the Main page. You will use this number to see if HP has a later version available.
    1. Go to the HP Software download page
    2. If you are presented with a page to enter your model number, type in your model number. For example, Pavilion p6230f or TouchSmart 600-1050uk.
    3. Select the version of Windows the computer is using.
    4. Click the BIOS link.
      • If a BIOS update is not listed, HP does not have a BIOS update posted for your computer at this time.
      • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your computer. To do this, turn off the power to the computer, remove the side panel, and read the name printed on the motherboard. The name of the motherboard should match or be similar to the name of the download link.
      • If a BIOS update is listed, continue to the next step to download and install the BIOS update.
        Click the download link. The instructions for downloading and installing BIOS updates vary. For most computers with Windows XP, download the file, open it and follow the on-screen instructions. For many computers before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive. The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
        2. Press the F5 key to load the default BIOS configuration.
        3. Select YES by using the arrow keys, and then press Enter .
        4. Press the F10 key to save the settings and exit.
        5. Select YES by using the arrow keys, and then press Enter .
        When the BIOS update is complete, the new BIOS revision number is updated on the Main BIOS screen.
Feb 28, 2011 | Compaq Presario 700 470024-192 Notebook
Hi, I have a Acer Aspire One (mdl ZG5) computer that was locking up, I attempted to format and reload the defaul system config from the hidden disk partition. The process started and then I received the...
Go to the Acer web site Support and Drivers, put your model number in, your operating system and order a DVD with a factory image for your Aspire One. It may cost you, but maybe not. Next order on optical drive that runs on two usb ports from eBay. I have one that costed $50 with shipping or maybe a local tech has one.
Oct 14, 2010 | Computers & Internet
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
Not able to complete windows xp setup
First let's try to "flash" the BIOS to correct the erroneous data crashes. Here's the link for the motherboard:
http://www.asrock.com/mb/overview.asp?Model=P4VM8
After flashing go back to the BIOS and setup the appropriate settings, after that reboot and try to load Windows. If this fails then possibly you may have faulty memory modules or they are not seated correctly in the motherboard, try swapping them, hopefully they are the same. I hope this helps.
Jul 03, 2009 | Asrock P4VM8 Motherboard
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Desktop hp Product Number P6402A
Step 1: Find the current BIOS version number
  1. Turn ON your pc. When the first screen appears, press F1 to enter the BIOS Setup. On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
  2. The BIOS revision number is listed on the Main menu. Write down the current BIOS version that is listed.
  3. To exit the BIOS setup screen, press F10 , select Yes , and then press the Enter key.
Step 2: Check the Drivers and Downloads page for BIOS or ROM updates
  1. Go to http://h10025.www1.hp.com/ewfrf/wc/softwareRedirector?lc=en&dlc=en&cc=us&product=67009&docname=c00007682 enter the model of the PC (for example, Presario 5002US or Pavilion a518d), and click the download button.
  2. Click the link for the PC Operating System (like Windows XP).
  3. Try to find the BIOS update listed under the heading, BIOS , BIOS- System , or RomPaq.
    NOTE: The term "Rompaq" refers to BIOS updates for Compaq Presario PCs prior to 2002.
  • If a BIOS update is not listed, HP does not have a BIOS update posted for your PC at this time.
  • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your PC. This can be done by turning off the power to the PC, removing the side panel, and reading the name that is printed on the motherboard. The name of your motherboard should match or be similar to the name of the download link.
  • If a BIOS update is listed, proceed to the next step to download and install the BIOS update.
Step 3: Download and install the BIOS update
  1. Click the download link. The instructions for downloading and installing BIOS updates vary.
  • For most PCs with Windows XP, download the file, open it and follow the on-screen instructions.
  • For many PCs before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive.
  • The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens.
  1. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
  2. Restart the PC and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  3. Press the F5 key to load the default BIOS configuration.
  4. Select YES by using the arrow keys, and then press Enter .
  5. Press the F10 key to save the settings and exit.
  6. Select YES by using the arrow keys, and then press Enter .
Please rate this solution. Thank you.
Feb 01, 2009 | Computers & Internet
My laptop is not switching on
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Oct 22, 2008 | Toshiba Computers & Internet
XP install errors
Try to copy the content from CD to USB flash stick and run the installation from stick. Remember to have set the USB disk for booting in BIOS. I had the same problems. I think it's because it tries to unpack some files on the drive it is installing from (CD can't be the one) - some wrong settings.
May 28, 2008 | Microsoft Windows XP Professional
Error loading operating system
Here you go! SYMPTOMS loadTOCNode(1, 'symptoms'); When you restart your computer after the file-copy portion of Windows XP Setup, you may receive the following error message: Error loading operating system
CAUSE loadTOCNode(1, 'cause'); This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP. uparrow.gif RESOLUTION loadTOCNode(1, 'resolution'); Warning This article contains steps that may involve changing your BIOS or complementary metal oxide semiconductor (CMOS) settings or that may require you to make physical changes to your computer hardware. Incorrect changes to the BIOS of your computer may create serious problems. Microsoft cannot guarantee that problems that result from changes to your BIOS can be resolved. Change your BIOS settings at your own risk. If you need help with any of these steps, contact your hardware manufacturer and note that making either hardware or BIOS changes to your computer may invalidate your warranty. If you do not want to make hardware changes to your computer, you can take your computer to a repair center.
To resolve this issue, use one of the following methods: • Make sure that you are using the latest BIOS revision for your computer. Contact the computer manufacturer to inquire about how to obtain and install the latest BIOS update that is available for the computer. • If you are using an IBM computer with an AWARD BIOS version 4.5x, visit the following IBM Web site: http://www.pc.ibm.com/ww/hdd/hddredirect.html (http://www.pc.ibm.com/ww/hdd/hddredirect.html)Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
Apr 25, 2008 | Acer Aspire 5100 Notebook
ASUS P4SP-MX Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
