Question about Vector 955 Radar Detector
Faulty Buttons Bel V955 When it turns on, it doesn't do its normal start up, doesn't pick up any threats at all, and after a few seconds, all the buttons lock up. i have tried resetting the detector but that doesn't work.
    Problem Solver:
  • 11 Answers
Return to Beltronics for repair. 1-800-341-2288.
Posted on Feb 07, 2013
3 Suggested Answers
SOURCE: how to open Bel 980 case
they are two on back thke the bottem then the top will come off the problem is there are two hinges in the front part on each side u have to compress each side with a very tiny flat head screwdriver. note be very careful this unit is not make to take apart easy but it can be done i have the same problem i am going to radio shack to see if the have the part for the voltage but first i am going to re sader the contection first. hope this works mark
Posted on Apr 24, 2008
SOURCE: Broken Cord plug
you can buy new ones on ebay
Posted on May 05, 2009
My screen is white
if it doesn't turn off you need to hold the power button 8 seconds
shut the console.
remove the game ship
using a tooth pick, press a small button inside the slot
Now power on and it should be fixed.
Still need help, search in You tube for
How to get rid of the dsi white screen of death
Mar 28, 2015 | Nintendo DSi Black Console
How do you turn off the Vmatic amber light on a
Press both the reset and mode buttons at the same time. Turn on the ignition. Keep the buttons pressed for 5 seconds. Light will start blinking. Release the buttons and the light will go out.
Dec 12, 2009 | Honda Silverwing 600 Motorcycles
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Beltronics radar detector gives constant alert after startup.
This is caused by the RD's local oscillator becoming unstable at higher temperatures due to a component which has become defective. Since this is an older radar detector model, you will have to pay a service charge to have it fixed. On the other hand, perhaps it is time to upgrade your remote installation to either the Escort 9500ci or the Bel STi-R setups? These newer models from Bel/Escort provide much better performance.
Apr 03, 2009 | BEL 915R Radar Detector
Beltronics V955 Chirps on all bands for 10 minutes when cold
This is most likely caused by a poor connection between the antenna ridge and the local oscillator board. Another possibility is an uncontrolled LO chamber harmonic due to the cold temperatures. Regardless of the cause, your V955 is under warranty and Bel will fix it for free -- as long as you include a photocopy of your sales receipt. Go to Bel's web site (www.beltronics.com), and either call their 800 number or do the online chat in order to get a RMA number.
Jan 06, 2009 | Vector 955 Radar Detector
Sleep function holds for only a few seconds then reverts to normal
Are you using an optical mouse? If so, try turning it upside down before entering sleep mode. On some surfaces (with some mice only), the mouse picks up movement even if perfectly still.
Oct 23, 2008 | Computers & Internet
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Different respose in two different vehicles
does the pickup have an aftermarket alarm system installed (not fasctory)? If so the alarms perimeter sensor is not wired properly and is on all the time (not when the alarm is armed).
Jan 28, 2008 | Vector 955 Radar Detector
Bel RX65 not working properly
Regarding the problem of the unit turning on for a second, then turning off after you plug it in....
Plug it in and hold the power button down for 5 seconds. This resets the unit. The unit will still turn off after this however. After that, push the power button on again for one second and it should remain on. Good Luck!
Jan 12, 2008 | Pro RX65 Radar Detector
Vector 955 Radar Detector Logo
81 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
