Question about Philips Televison & Video
We have a Phiphs flat screen TV model number 26PF5321/10. There is intermittent lack of control and volume increase up to maximum. What could be the problem?
    Habit-Forming:
  • 163 Answers
Check out the remote for sticking keys if Volume up is stuck the it will stop any other function. Is it possible that the remote has had a liquid spillage if so it will need dismantling and cleaning with Isopropyl Alcohol
Posted on Jun 16, 2008
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Volume intermittently increases all the way to 100 and cannot be controlled by the remote
This happens with some models. You can open the TV from the back and disconnect the connector for the side control board. You will only have control via the remote but your volume issue should be resolved.
Apr 12, 2014 | Samsung Televison & Video
My Dell Latitude E5500 speaker is too low, how to increase volume?
If you have volume control in the system tray (bottom right corner), double-click it. In Windows XP you will see all the sound controls. Increase all to the maximum level (except microphone).
Use the buttons close to the screen to increase the volume.
There is a volume control in the player you are using. Increase it to the maximum.
If it doesn't help, please let us know.
Sep 10, 2011 | Dell Latitude E5500 Laptop
Have no sound on my 50 in flat screen sanyo
Check the volume control and increase it to the maximum. if it does not come up then replace the sound IC. Thank you for using Fixya.
Sep 06, 2011 | Televison & Video
How to increase max vol further on, of my laptop gateway mx6956 as it is horribly low
Hello, You can increase the volume of your laptop by, first check the speaker and headphone icon whether it is set to 100%.You can see it in the system tray or by the right hand side at the bottom of your screen or at the control panel,click on SOUND and increase the volume. Note the software you are using like window media center, VLC player, real player and the likes should also be increase to maximum, then if your computer has an external control for the volume, make sure you increase it to the maximum. HOPE THIS HELPS
Nov 23, 2010 | Gateway MX6956 Notebook
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
Jan 11, 2009 | Soyo DYLT032D 32 in. LCD Television
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Televison & Video Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
